PCB Legs
Fairly new to PCB assembly.  I’ve seen the legs which effectively bolt to a surface and then the PCB screws into these.  Is there an equiavlent where the leg can be glued/stuck to a surface?  Ideally I would want plastic ones so the PCB can clip onto the leg?
Many thanks,
James
Yes, you could see that kind of spacers or as you call it legs on the computer motherboards. Im not sure where to get it, but it shouldnt be hard. Ask the guys from computer repair service.
ahh ha!
I found just such a thing recently and was well pleased, very cheap and saves a whole lotta drilling and bolting…
http://www.rapidonline.com/productinfo.aspx?tier1=Tools%2c+Fasteners+%26+Production+Equipment&tier2=Fasteners+%26+Fixings&tier3=Fixings+%26+PCB+Pillars&tier4=Self-adhesive+PCB+pillars&moduleno=64771
Or you could try Wilba’s JB Weld trick…
Thanks everyone, especially David - those are exactly what I need.
James
