PCB Layout
Hi All,
I’m new working with this project, so excuseme if someone alreay made this question.
I tried to see the PCB (mbhp_core_v2.brd) but apparently it was made wth Eagle 4.1, but this version of Eagle program isn’t for download (4.09 is dowloadable). I need to print the PCB for construction, actually i don’t want to modify core’s PCB. There is an high quality printable version available or I need Eagel 4.1 ?.
Thanks in advance,
dsor.
Eagle 4.11 is downloadable from CadSoft, just check out download area:
http://www.cadsoft.de/freeware.htm
Well, I tried to export (with CAM processors “layout” job)
design to EPS, but didn’t get bottom layer to show anything at all :wink: also vias don’t show as they should. Check this topic:
http://www.midibox.org/cgi-bin/yabb/YaBB.cgi?board=concepts;action=display;num=1068767866
Maybe arumblack could help you and email his correct pdf versions for you (as they are not yet on midibox portal)
Bye, Samppa
//edit: More info
surely, if he lets me know what he needs.And of course where to send them.
First of all thanks moebius and arumblack for the response.
I donwnloaded Eagle 4.11 (using moebiu’s link !!) , so I will use Eagle to generate an ‘high quality’ PCB hard copy.
Regards from Argentina,
dms./
No Prob!
