I dunno if its switching or linear type, but I powered an analogue audio mixer project from an old Amiga PSU, which was very quiet for audio. Â it was handy, cos it has +/- 12v and 5v outputs
I’m not sure if it was an A2000 or A3000 Amiga (Video Toaster rig) that I serviced many years ago but it had a switching supply in it.
Switchers can be used in any application but the output MUST be filtered to suit.
My QSC power amps and Yamaha board have switching supplies in them, but correct filter design makes the noisy power a non issue.
Here are some major differences between linear and switching power supply designs:
Linears always have large transformers, switchers use small ones. I have rarely seen a normal (+5,+12) linear P.S. with a transformer small enough to mount on the PC board with the rest of the power supply circuit.
Linears use large filter capacitors, again usually too large to board mount.
Linears throw tons of heat. They are really really ineffiecient compared to a switcher.
So if you are looking at the board in the P.S. and it takes AC line voltage in and does not have a transformer that is at least half the size of that board, it’s probably a switcher. :)
There are exceptions to these rules, but what you find at the electronics dealer or in a finished product will likely meet one of the above descriptions.
Switcher P.S. design is a throwback to the cold war tech race, smaller more efficient P.S. designs were needed “for soldiers to carry”. Many consider Peter Chou to be the father of the modern switching power supply design, if you are looking at a +5 & +12 from a computer it is either his design or a clone of his design. Unfortunately this design (flyback style) is the most noisy. :)
If you can’t figure out what you have, Take some pics and let me know, I’ll help. Now if someone would help me with some real world knowledge of the filtering…the stuff in the books (I have) just does not cover this.
Sorry for the long post!
SmashTV
