It don’t have buffer on the midi out, but it works good for me. Without the buffer IC i was able to stuff the optocoupler and the other components in the housing for the DB15 connector :)
Another question:
I didn’t get hands on 33pF caps for the XT resonance circuit on the CORE in my eager to get the CORE running so i stuffed it with 2*22pF instead. Anyone see problems with that ?
I once tried to stuff one of those circuits with buffer IC in to DB15 shell (point to point wiring) and gave up Maybe I should have another attempt.. maybe eith that using transistors as buffer.
I don’t know about those caps.. BUT It’s simply microcontrollers external resonator clock, so If got it running with 22pF I don’t see any reason to change those
