Hello everybody,
since I have some encoders (but not all) in my MBSEQ changing values in the opposite direction, I thought the best way is to tell somewhere in the software which encoder is reversed (has its pins swapped) and which is not.
So I’ve made a little patch to the MIOS code making it able to read a flag in the encoder table and give a negated (2-complement) incrementer to the user application if that flag is set.
Here’s the patch against MIOS v1.9f:
diff -Naur mios_v1_9f_src.orig/src/mios_enc.inc mios_v1_9f_src/src/mios_enc.inc
--- mios_v1_9f_src.orig/src/mios_enc.inc 2008-01-20 23:39:02.000000000 +0100
+++ mios_v1_9f_src/src/mios_enc.inc 2008-02-22 19:43:43.000000000 +0100
@@ -16,6 +16,7 @@
MIOS_ENC_MODE_NON_DETENTED EQU 0x00
MIOS_ENC_MODE_DETENTED EQU 0x80
MIOS_ENC_MODE_DETENTED2 EQU 0x81
+MIOS_ENC_MODE_REVERSED EQU 0x40
ENC_STAT_ACT_A EQU 0 ; Current status of channel A
ENC_STAT_ACT_B EQU 1 ; Current status of channel B
@@ -801,6 +802,10 @@
addlw 1
addwf FSR0L, F
+ ;; now TABLAT contains encoder flags, so it's a dummy read
+ ;; if incrementer is zero or we can read "reverse" flag otherwise.
+ tblrd*+
;; temporary disable the IRQs
IRQ_DISABLE
@@ -814,6 +819,12 @@
;; enable IRQs again
IRQ_ENABLE
+ ;; makes incrementer negative if encoder is reversed mounted
+ BRA_IFCLR TABLAT, 6, ACCESS, MIOS_ENC_Dont_Negate
+ negf WREG
+MIOS_ENC_Dont_Negate
;; save incrementer in MIOS_PARAMETER2
movwf MIOS_PARAMETER2
@@ -830,7 +841,6 @@
MIOS_ENC_Handler_Loop_Next
IRQ_ENABLE
- tblrd*+ ; dummy read
incf MIOS_TMP_CTR, F, BANKED
BRA_IFSET MIOS_TMP_CTR, 6, BANKED, MIOS_ENC_Handler_Loop_End
rgoto MIOS_ENC_Handler_Loop
That’s the same content of the attached file. To use it on your application, just add this row in mios.h of the app’s source:
and set your reversed encoders this way:
ENC_ENTRY 2, 6, MIOS_ENC_MODE_DETENTED2 | MIOS_ENC_MODE_REVERSED ; this is a reversed encoder
ENC_ENTRY 2, 4, MIOS_ENC_MODE_DETENTED2 ; this is a normal encoder
I hope it gets useful for somebody.
Greetings, Enrico
[revenc.diff.txt](< base_url >/applications/core/interface/file/attachment.php?id=638)
[revenc.diff.txt](< base_url >/applications/core/interface/file/attachment.php?id=3780)
