Hi there all, I started quite a few years ago now down the route of building me own midibox. Life took over and i just came over a box of all the old bits i had prepared already. I don’t know if the project has moved on substantially since my last visit, but before i throw the bits i have in the bin thought i would offer them out. Soldering on some of it not great.
I have the following bits;
DIN and DOUT pcbs undrilled
One DIN board with IC mounts and pcbs pins on either end i was going to use to connect
JDM Board with IC holder serial connector and connection pins mounted
Main boards with pins and IC mounts
2 of AIN X$ boards with IC mounts and pins mounted.
DOUT Board with PIns IC mounts and resistors all mounted
I also have all IC and chips serrate.
2no pic18f452 chips
1 bag with 22 other ICs (i presume i had bought everything to complete)
Bag of connector and connector pins which would be used to make ribbon cables or looms to connect boards
Resistors, Transistors, Diodes, Capacitors, clock
Left over pins for other pcbs.
PCB etching tray, two un-etched pcb boards, Printer transfer paper for pcbs, software on floppy (i think, cant check!) (no solution to etch pcbs)
Also have a C64 with 8580 chip.
Please let me know if you are interested or want any more detail.
Regard,
Phil
