The pin arrangement on the bridge rectifier on that page is different to the ones I use, which has the “~” pins diagonally opposite each other, the “-” and “+” pins in the other corners. Perhaps yours is the same, and you’re connecting it wrong, which will short circuit between the AC inputs!
Use a multimeter to test the actual diodes in the bridge rectifier.
Wow, I didn’t realise that so many people actually looked at my page - I better get on with buildingthe rest of the damn thing! I’ll also update it with the info. about this problem, 'cause that’s liable to catch a few people out if they’re not expecting it…
