Hi midiboxers!
Mr Murphy is ever present… Â :-X
I think I’m not understanding something or that I have something broken in my modules…
Theis is my history… please … a tip is welcome…
Thank u in advance
Ale
Core:
with a 6N139
It sends continuosely cc messages for brighthness and volume on all midi channels.
SOLVED connecting all unused pin of J5 to ground.
6N139 seems to work well.
Display:
Solved all probs cheching the cable, now it works well.
DIN: I’ve connected one module with all ics and resistances but with only 8 buttons connected (under and above ic1.
0nly button 1 (enter) works. It calls main menu but the core gives out some note on messages (see below) when pushing the button; releasing it the core gives out the note off messages correspondent to note on messages sent before.
May be Pic doesn’t recognize Lcd so it disable Menu buttons?? Â How can I check this signal from Lcd to Pic?
Note on/off messages: ch1 Eb4; ch1 D4; ch1 C#4; Ch8 C3; Ch7 C3; Ch6 C3; Ch5 C3; Ch4 C3; Ch3 C3; Ch2 C3; Ch1 C3; Ch16 C3; Ch15 C3; Ch14 C3; Ch13 C3; Ch12 C3; Ch11 C3; Ch10 C3; Ch9 C3.
It repeats a C6 note on for midi channels from 8 to 1; after a C4 note on on all midi channels ( 8 to 1 and 16 to 9 ); after a C5 note on on all midi channels ( 8 to 1 and 16 to 9 ).
After it sends Rev deph, chorus depth, Brightness and volume cc with value 0 on every channel
AIN: Only ic 1 is in the socket analog input 2-3-4 are connected to ground. I’ve connected only pot 1 and 2, all the other outs ( pot 3 / pot 8 ) are connected to ground.
Pot 1 sends double messages on ch1 and ch4 (all reverb depth) on display I see bar #1 displayng correctly and bar # 4 flickering but displaying the same value of bar #1.
Pot 2 do the same of pot 1 but for ch 2 and ch 3 and bars #2 and #3.
??? Â ??? Â ??? Â ??? Â ??? Â ??? Â ??? Â ??? Â ??? Â ??? Â ??? Â ??? Â ??? Â ??? Â ??? Â ??? Â ??? Â ??? Â ??? Â ??? Â ??? Â ??? Â ??? Â ???
