Optical Sensor for Encoder/Jogwheels
Hi TK and all others,
while browsing the web for different jogwheel/encoder types
i found some interesting projects about using the sensor chip from an optical mouse.
http://ferretrobotics.blogspot.de/2011/01/interfacing-optical-mouse-usb-with-pic.html
and here more technical informations:
http://www.ele.uva.es/~pedro/optoele/LEDs/Appnotes/opticalMouse.pdf
http://www.avagotech.com/docs/AV02-1184EN
Would this not give more then enough resolution?
The Chip seems to be useable without additional circuits.
It uses a ps/2 and a quadrouble output mode.
Unfortunatelly i do not have the knowledgement to create a
midibox compatible peace of hardware in reality.
But maybe someone can use this informations :wink:
Best regards
Marxon
The encoder wheel of a mouse can already be scanned fast enough (the scan rate is 1 mS)
You only need to add a schmitt trigger after the encoder outputs to ensure proper digital signals
Thanks, got it working! :ahappy:
I disassembled an old mouse, used a 74HC14 schmitt trigger and connected it to my SeqV4:
