So as per the other thread in here, I am tracking down some new 60mm faders. I had a look on Farnell (seems to be the easiest electronics site to navigate!) and came up with a HELL of alot of results.
I found 5 different 60mm 10k ohm panasonic faders…all similar price…but I have no idea what their real differences are? Also, I can’t see if it is mentioned whether they are linear or log? im sure it is…but not in language I can understand (ie. I don’t speak smart electronics talk).
The one thing I did notice between them all is they obviously have different power ratings. Is there any specific desired power rating for midibox64s? or just the less the better?
here they are:
http://sg.farnell.com/panasonic/ewaq10c15a14/potentiometer-slide-10k/dp/8796157
http://sg.farnell.com/panasonic/ewaq30c15d14/potentiometer-slide-10k/dp/8796190
http://sg.farnell.com/panasonic/ewaq12c15b14/potentiometer-slide-10k/dp/8796173
http://sg.farnell.com/panasonic/ewaq10c15d14/potentiometer-slide-10k/dp/8796165
http://sg.farnell.com/panasonic/ewaq30c15a14/potentiometer-slide-10k/dp/8796181
also found these ones:
http://sg.farnell.com/bourns/pta6043-2015dp-a103/potentiometer-slide-10k-60mm/dp/1688417
http://sg.farnell.com/bourns/pta6044-2015dp-a103/potentiometer-slide-10k-60mm/dp/1688419
http://sg.farnell.com/bourns/ptb6043-2010bp-b103/potentiometer-slide-10k-60mm/dp/1688410
any advice greatly appreciated ![]()
