Hey…
After reading about the ‘Nomical Project’
for the control surface of his DB50XG I got thinking if the same could be done for the Yam PLG150AN/DX dsp cards…
What I was thinking was to use the Kenton Plugin station to handle the audio i/o (or a homebru job if it’s easy enough) and then a MIOS based control surface to handle the GUI and control surface…
So for instance you could have both a AN and DX card in the plugin station and be able to control them both with a simple syx msg* :)…
I’m assuming I could use the SID f/w or perhaps even Nomical’s DB50XG control code for the adaption to handle this - right?
On another note, could MIOS do anything to an old Casio HT-3000?
T???
Peesh…
Dan //
* I guess an internal eeprom would take care of that tho ![]()
