Note copy or Note memory ?
I’m building patterns with a lot of identical notes for note length.
Until now I set the notes manually for each step, which is a time consuming job.
There is a way to copy the same note on the next step ?
Or I can change the C3 note that is default when I activate step with another ? (change it easily on what note I want)
Thnx!
If I understand correctly, you could use the copy/paste functionality, or you could use the all function to set all of the steps in a pattern to be the same note/length/vel/etc. Then turn them on/off as needed.
Luke
I know how to use ALL function. Also know how to set how many steps will be affected by all function.
I want to set for example on a pattern of 128 steps : 30 steps one note, 60 steps other note etc.
I know how to set them, but I wanted to know if there is a simple way.
I discovered how to use step (or steps) copy and paste them :), I wanted to know if something changed on updates and I missed it.
Nothing changed, this feature is already available in MBSEQ V3.
But of course, due to the high variety of functions (and alternative solutions), there are always certain features worth to discover :slight_smile:
