nordbeat midi remoter
Any of you have seen or try this new soft ?
http://www.nordbeat.com/db/midi_remoter.asp
In fact i didn’t arrive to use it with any synth soft or other soft …  ;D
It could be a usefull tool … if we understand how it  works !!  ;)
Gilles
Gilles
Havn´t seen it before, so thanks for the info!! :slight_smile:
So far i´ve just tried it out for a bit, but it seems like a very nice tool and it´s very easy to get it to talk to sid :).
js
js
You success to control some soft synth ?
…how ?
And the SID ?
Gilles
…how ?
And the SID ?
Gilles
Both,
Here a little step by step on how to make a slider that controls the sid.
session -> new session.
(enter a name) -> Ok.
Edit -> Edit matrix (shortcut F5 toggle edit mode).
select a slider from ‘Tools’.
click twize on the orange line in the ‘Action Editor’ (if it isn´t visible click on the slider).
select CC Controller change.
select the CC (fx. 40 for Sids 1/2/3 Arpeggiator Rate) midi-port & midi-channel and click save.
Hit F5 again to exit edit mode.
It´s pretty much the same for buttons etc. Good luck!!
let me know if there any trouble, im on my way to be and almost sleeping now so I might missed somthing..
js
Both,
js
ok JS…
I finally found where was my mistake … my midimerger was in default …
BTW , This is a great control tool for Sid !!!
I’m now trying to control SID + Reason in the same time …
not the same … :wink:
Gilles
ok JS…
Gilles
