none audio use concept ?
Hello,
I would like to check if my concept will work well with the MIDIBox64 Setup. Here is what I need:
  • up to 10 rotary encoders with at least 10-bit resolution
  • about 10 buttons and 10 leds
  • LTC module to communicate via RS232 port
  • custom software ( will support MIDI protocol to understand the MIDIBox, but no audio functionality )
As I understand it, since I won’t use a LCD, I will need to programm the encoders to be used as 14bit volume controlers for example!?! Can this be done over the serial interface?
I’m a newbee to MIDI so I need to ask!
Thank you for any help/tipps.
For a newbie a very hard task!
First: No, with the MB64 setup this is not possible. Furhtermore, programming the MB64 without the LCD is very hard!
I would stick to the already built stuff (look up in the MIOS Downloads for more).
