hallo hallo
this is the matter :
i use an audio track midi/usb interface and an esi u2a soundcard/usb to interface mididbox and my guitar
but i got noises by toggling the encoders of the midibox trought the sound card ie whenever the midibox sends a midi signal it is captured also by the soundcard as an high frequency noise not a real high level but enough to be considered a problem
has anybody had the same problem? is it aknown issue or is it due to my usb hub? btw i run everything on an averatec laptop with VIA usb hub
thanks in advance
cheers
simone
