No sound voltages OK!?? (solved)
Hi
My SID is not making any sounds at all. First it made som but so low volume you could barley hear it. Whats going on here? What voltage is recomended for J3 audio out? All others seem ok !!
There is not even background noise comming out! Could it be a broken SID? I have tried all night to get it right. But it just does not make sounds.
Do you hear a startup sound ? ?
Checked your connections/soldering ? [mainly between core & SID] …use a multimeter
Have you upload patches ?
keep trying!
but also if you have another sid chip give it a go.
What start up sound? Have not heard it. And now there is no MIDI comunication? The voltages was bad for a short time (like 3) where it should have been 5 and 12. Maybe its the CORE. I am  almost mad now. Must sort the MIDI before anything else.
Havent uploaded any patches whats the use (no sound)? The SID should make sounds when playing via MIDI keybord right?
I just have written a walkthrough which should give you some hints how to get the box running: http://www.ucapps.de/midibox_sid_walkthrough.html
OK GREAT!!
By the way how easy is it to fry the SID?? Hope it still works.
Looks like its the CORE not working, I am going  toorder a new set. The solders looks like dog poo! I have another up and running since its going  to be 3 SID:s  inmy synth.
I see aloot  you have had problems with no sound here. Did you get it right in the end ???
My worst fear is that I killed my SID. Or that it was dead from the start. Is no sound an indicator that the chip is dead?
Ill just keep trying  to get it going. What else could  be wrong? Some static noise should come out if its dead right?
:smiley: Got the startup tune now! But its way  to low. Preamp to max on my mixer and channelstrip to max? Still something wrong??? What  canit be???
hi,
preamp to a max ???
i know that my sid is not as loud as my other synths but this seems wrong to me (i amplify it a tiny bit more than other synths)
i would just go thru the walkthrough step by step; and write down results; after this it would be easier to ask/answer questions.
btw dunno if this makes sense but..have you checked the transistor in the output stage of the sid (right type, right orientation), i guess this is for amplifying the signal.
cheers , marcel
The transistor is not the BC547, its a CBC547 can i get som help on the pinout since I think its the problem now??? I  am getting nowere on  myown… ???
Maybe I should try to clock the sid from the core? Remove to clock from the sid board. Would it help? I am givving it a rest today… Havent got any other ideas! ???
dontthink this will solve your problem;
bout the transistor; you could try and find a datasheet, but i couldn’t (is it really a CBC547?).
BTW did you buy a kit from mike/smash?>> if so the parts you got will be fine, your problem will be something else.
of course it could be a fried SID; but there is no quick way to test; you could put it in a working C64 and try a sid tune from a game or so
sorry i can’t be of more help..
goodluck, marcel
Yeah. its wierd. but the part is printed CBC not BC… And I cant find anything about CBC… like there is no thing like it???
The startupsound is like a low rapid pip pip pip pip, then there is no response on midi??? Getting new parts and som new SID:s. I dont have a working C64 now only sidchips… :frowning: But clocking from the CORE solved a simular problem for someone here at the forum..? I will try tomorow. I could also try ordering new CB:s and fit them. Now i must hunt down some SID chips… Later!
I think it´s an BC547C, even if there is printed CBC…
Just try another BC547C,… but I don´t think, that´s the problem…
Check all connections again,again,again,… touch them with your soldering iron… and also be shure, that every part is stuffed at the right place on PCB,.. in the right way.
Greets,
pwx
:o :o :o :o You will never quess what it was. Its solved now. My phono jach was not working. Replaced it and sweet sound at last.
