.ngr refresh problem
Hi all,
i use this script to change the function of enc=2 via button=1371 and button=1372.
.ngc
EVENT_BUTTON id= 70  hw_id= 70  type=Meta   meta=SetBank          range=1:2    meta=RunSection:2
EVENT_BUTTON id=1371  hw_id=1024    button_mode=toggle range=0:127     Bank=2    type=NoteOn    chn=3    key=41
EVENT_BUTTON id=1372  hw_id=1017    button_mode=toggle range=0:127     Bank=2    type=NoteOn    chn=3    key=42
EVENT_ENC     id=   2 hw_id=  2     type=cc chn= 2 cc=111             range= 0:127
EVENT_ENC     id=1371 hw_id=  2     type=cc chn=11 cc= 41 Bank=2    range= 0:127
EVENT_ENC     id=1372 hw_id=  2     type=cc chn=11 cc= 42 Bank=2    range= 0:127
.ngr
if ^section == 2
  if (iD)BUTTON:1371 < 1
    set_active (id)Enc:1371 0
    else set_active (id)Enc:1371 1
  endif
  if (iD)BUTTON:1372 < 1
    set_active (id)Enc:1372 0
    else set_active (id)Enc:1372 1
  endif
endif
exit
Now the problem:
i have to push button=70 a second time before
enc=1371 and enc=1372 get updated but i like them to update allready
during hold down button=70 for the first time.
How can i achieve this?
Best regards
Marxon
What do you mean with:
what kind of update do you expect?
If you mean, that they should be handled by the .NGR script, then I would say that this is unexpected.
Could you please add some debug messages (via the “LOG” command) to the script and doublecheck, which parts are executed?
Hi Thorsten,
somehow i killed the code, yesterday.
Now i allways get this error:
[385453.834] [MBNG_FILE_C:143] ERROR: '(iD)BUTTON' not found in event pool by 'if' command!
[385453.835] [MBNG_FILE_C:143] ERROR: invalid left value '(iD)BUTTON' in 'if' command!
[385453.836] [MBNG_FILE_R:143] stopped script execution due to previous error!
No matter what button i use in line 143. Strange…
Would you please take a look at the code?
It happens at .ngc line 10
Thank you very much!
[M³.zip](< base_url >/applications/core/interface/file/attachment.php?id=11084)
the .zip file contains a M3.ngc and default.ngr file.
But M3.ngc will use M3.ngr
So: could it be that you edited the wrong .ngr file (default.ngr instead of M3.ngr)?
No :slight_smile: I just forgot to rename both “M3”.*
The button can’t be found because it has an invalid fwd_id argument, and therefore was rejected:
[79761.466] [MBNG_FILE_C:651] ERROR: invalid fwd_id controller name in EVENT_BUTTON ... fwd_id=<LED
[79761.469] [MBNG_FILE_C:653] ERROR: invalid fwd_id controller name in EVENT_BUTTON ... fwd_id=<LED
[79761.469] [MBNG_FILE_C:655] ERROR: invalid fwd_id controller name in EVENT_BUTTON ... fwd_id=<LED
[79761.472] [MBNG_FILE_C:657] ERROR: invalid fwd_id controller name in EVENT_BUTTON ... fwd_id=<LED
[79761.473] [MBNG_FILE_C:659] ERROR: invalid fwd_id controller name in EVENT_BUTTON ... fwd_id=<LED
[79761.477] [MBNG_FILE_C:661] ERROR: invalid fwd_id controller name in EVENT_BUTTON ... fwd_id=<LED
[79761.477] [MBNG_FILE_C:663] ERROR: invalid fwd_id controller name in EVENT_BUTTON ... fwd_id=<LED
[79761.480] [MBNG_FILE_C:665] ERROR: invalid fwd_id controller name in EVENT_BUTTON ... fwd_id=<LED
[79761.480] [MBNG_FILE_C:669] ERROR: invalid fwd_id controller name in EVENT_BUTTON ... fwd_id=<LED
[79761.484] [MBNG_FILE_C:671] ERROR: invalid fwd_id controller name in EVENT_BUTTON ... fwd_id=<LED
[79761.484] [MBNG_FILE_C:673] ERROR: invalid fwd_id controller name in EVENT_BUTTON ... fwd_id=<LED
[79761.487] [MBNG_FILE_C:675] ERROR: invalid fwd_id controller name in EVENT_BUTTON ... fwd_id=<LED
[79761.487] [MBNG_FILE_C:677] ERROR: invalid fwd_id controller name in EVENT_BUTTON ... fwd_id=<LED
[79761.491] [MBNG_FILE_C:679] ERROR: invalid fwd_id controller name in EVENT_BUTTON ... fwd_id=<LED
[79761.491] [MBNG_FILE_C:681] ERROR: invalid fwd_id controller name in EVENT_BUTTON ... fwd_id=<LED
[79761.554] [MBNG_FILE_C:683] ERROR: invalid fwd_id controller name in EVENT_BUTTON ... fwd_id=<LED
[79761.554] [MBNG_FILE_C:813] ERROR: invalid fwd_id controller name in EVENT_BUTTON ... fwd_id=<LED
[79761.557] [MBNG_FILE_C:815] ERROR: invalid fwd_id controller name in EVENT_BUTTON ... fwd_id=<LED
[79761.557] [MBNG_FILE_C:817] ERROR: invalid fwd_id controller name in EVENT_BUTTON ... fwd_id=<LED
[79761.561] [MBNG_FILE_C:819] ERROR: invalid fwd_id controller name in EVENT_BUTTON ... fwd_id=<LED
[79761.561] [MBNG_FILE_C:821] ERROR: invalid fwd_id controller name in EVENT_BUTTON ... fwd_id=<LED
[79761.564] [MBNG_FILE_C:823] ERROR: invalid fwd_id controller name in EVENT_BUTTON ... fwd_id=<LED
[79761.564] [MBNG_FILE_C:825] ERROR: invalid fwd_id controller name in EVENT_BUTTON ... fwd_id=<LED
[79761.568] [MBNG_FILE_C:827] ERROR: invalid fwd_id controller name in EVENT_BUTTON ... fwd_id=<LED
[79761.568] [MBNG_FILE_C:831] ERROR: invalid fwd_id controller name in EVENT_BUTTON ... fwd_id=<LED
[79761.571] [MBNG_FILE_C:833] ERROR: invalid fwd_id controller name in EVENT_BUTTON ... fwd_id=<LED
[79761.571] [MBNG_FILE_C:835] ERROR: invalid fwd_id controller name in EVENT_BUTTON ... fwd_id=<LED
[79761.575] [MBNG_FILE_C:837] ERROR: invalid fwd_id controller name in EVENT_BUTTON ... fwd_id=<LED
[79761.575] [MBNG_FILE_C:839] ERROR: invalid fwd_id controller name in EVENT_BUTTON ... fwd_id=<LED
[79761.578] [MBNG_FILE_C:841] ERROR: invalid fwd_id controller name in EVENT_BUTTON ... fwd_id=<LED
[79761.578] [MBNG_FILE_C:843] ERROR: invalid fwd_id controller name in EVENT_BUTTON ... fwd_id=<LED
[79761.846] [MBNG_FILE_C:845] ERROR: invalid fwd_id controller name in EVENT_BUTTON ... fwd_id=<LED
It seems that the displayed line numbers are not correct (I’ve to fix this)
But if you search for “fwd_id=<”, you will find the wrong definitions.
After correcting the syntax, “run 2” is executed without error
Aha! I totally overlooked those"<" and “>”, damn!
Ok i changed the .ngr
if ^section == 2
  log "Section is 2"
       log "deactivated"
    else
       log "activated"
    endif
  endif
This the output:
  • Hold button 70 pressed
    “Section is 2”
    “de/activated” (depending on actually status)
  •  Press  button1371
    “nothing”
  • Release button 70
    “de/activated” (status toggled)
It seems Set_active is executed to late.
It should be executed after pressing button 1371.
Well, in your .ngc setup the section is only executed with button id=70
You could execute it with id=1371 as well (just configure it as a meta event); the CC event could be sent with the “send <midi-event>” command from the .ngr script.
Do i need the CC midi out event at all, because i want to use the button only for the “if” condition to /deactivate Enc1371?
No, you don’t need it.
I don’t know why you assigned a CC to this event… if not necessary, why not triggering RunSection:2 with this button?
Ok thank you again Thorsten!
Its working without the CC too.
I also managed the refresh problem.
To sum up:
I have
-one “shift” button button id=26
-two “encoder on/off” buttons hw_id=1024, hw_id=1017
-one multi porpose encoder hw_id=1
Pressing the “shift” button together with one “encoder on/off” button
de/activates a function of the multi porpose encoder.
.ngc
EVENT_BUTTON  id=1371  hw_id=1024    button_mode=toggle range=0:127     Bank=2    type=meta      meta=runsection:101
EVENT_BUTTON  id=1381  hw_id=1024                                     bank=2 chn=3    label="^std_btn"    fwd_id=LED:1217
    #Encoder 1 on/off
EVENT_BUTTON  id=1372  hw_id=1017    button_mode=toggle range=0:127     Bank=2    type=meta      meta=runsection:102
EVENT_BUTTON  id=1382  hw_id=1017                                     bank=2 chn=3    label="^std_btn"    fwd_id=LED:1218
    #Encoder 2 on/off
EVENT_ENC     id=1371 hw_id=1    type=cc chn= 11 cc= 71 Bank=2    range= 0:127 enc_mode=Inc00Speed_Dec40Speed enc_speed_mode=fast:4 lcd_pos=1:1:1  label="^std_enc"
    #Multi porpose encoder function 1
EVENT_ENC     id=1372 hw_id=1     type=cc chn= 11 cc= 72 Bank=2    range= 0:127 enc_mode=Inc00Speed_Dec40Speed enc_speed_mode=fast:4 lcd_pos=1:1:1  label="^std_enc"
    #Multi porpose encoder function 2
EVENT_BUTTON id= 26 hw_id= 26      type=Meta   meta=SetBank  range=1:2  lcd_pos=1:1:1    label="^std_btn"
    # Shift Button
.ngr
if ^section == 101
    LOG "Volume 1"
                 LOG "VolumeENC 1 off"
      LOG "VolumeENC 1 on"
   endif
endif
if ^section == 102
    LOG "Volume 2"
                 LOG "VolumeENC 2 off"
      LOG "VolumeENC 2 on"
   endif
endif
Everything is working except that after release the shift button and press it again, then all encoders are “activated” again, regardless their previous state.
I hope my problem is understandable if not i can write it in german again :slight_smile:
Best regards
Marxon
Good progress! :slight_smile:
This shouldn’t happen if you remove “Bank=2” from the EVENT_ENC statements which should be controlled from the .NGR script.
Because with “Bank=2” the encoders will be part of the bank, and therefore automatically activated on each bank switching.
Thanks for your patience, Thorsten! :thumbsup:
This is the new code:
EVENT_BUTTON id=1371 hw_id=1024 range=0:127 Bank=2 type=meta    meta=runsection:101 button_mode=toggle
        #Encoder 1 on/off
EVENT_ENC  id=1371 hw_id=1    range=0:127 chn=11  cc=71 type=cc enc_mode=Inc00Speed_Dec40Speed enc_speed_mode=fast:4
EVENT_BUTTON id= 26 hw_id= 26   range=1:2          type=Meta   meta=SetBank  lcd_pos=1:1:1
        # Shift Button
if ^section == 101
    LOG "Volume 1"
      set_active (id)LED:1217 0
         set_active (id)LED:1217 1
   endif
endif
New code, new problem:
Disabling the encoder works but it does not get reactivated after pressing button id=1371 again.
Although i receive “VolumeENC 1 on”, nothing is sent when the encoder is moved.
But why?
I will try this out tomorrow.
Hi again,
have you tried it Thorsten?
EDIT:
It works with an additional
in the first condition.
Although it should not be necessary, right?
if ^section == 101
   LOG "Volume 1"
    endif
endif
Best regards
Marxon
Ok, now it’s clear to me what is going wrong here:
The parser doesn’t read commands after an ELSE statement.
On the other hand, it didn’t complain about the command - and this caused the confusion at your side.
Here a new version which prints an error message whenever a command is detected after ELSE or ENDIF
-> http://www.ucapps.de/mios32/midibox_ng_v1_029_pre3.zip
Good to know!
I often use commands after ELSE statements.
This maybe also explain one or other strange behavior…
Thanks Thorsten!
Best regards
Marxon
