thank you for the faster answer! Today I had try version 1.33pre1,2 and a older 1.32pre1 found in another topic. I not try with inverted DIN order, tomorrow I’ll check.
Thank you,
Mattia
This is my .NGC file:
RESET_HW
#SCHEDA 1
encoder MAP
ENC n= 1 sr=3 pins=2:3 type=non_detented
ENC n= 2 sr=3 pins=0:1 type=non_detented
ENC n= 3 sr=3 pins=4:5 type=non_detented
ENC n= 4 sr=3 pins=6:7 type=non_detented
ENC n= 5 sr=2 pins=2:3 type=non_detented
ENC n= 6 sr=2 pins=0:1 type=non_detented
ENC n= 7 sr=2 pins=4:5 type=non_detented
ENC n= 8 sr=2 pins=6:7 type=non_detented
Encoder events
EVENT_ENC id= 1 fwd_id=LED_MATRIX:1 fwd_to_lcd=1 type=CC chn= 1 cc= 16 label=“Gain %3d@(1:1:2)%B”
EVENT_ENC id= 2 fwd_id=LED_MATRIX:2 fwd_to_lcd=1 type=CC chn= 1 cc= 17 label=“Tone %3d@(1:2:2)%B”
EVENT_ENC id= 3 fwd_id=LED_MATRIX:3 fwd_to_lcd=1 type=CC chn= 1 cc= 18 label=“Volume %3d@(1:3:2)%B”
EVENT_ENC id= 4 fwd_id=LED_MATRIX:4 fwd_to_lcd=1 type=CC chn= 1 cc= 19 label=“Reverb %3d@(1:4:2)%B”
EVENT_ENC id= 5 fwd_id=LED_MATRIX:5 fwd_to_lcd=1 type=CC chn= 1 cc= 20 label=“Time %3d@(1:5:2)%B”
EVENT_ENC id= 6 fwd_id=LED_MATRIX:6 fwd_to_lcd=1 type=CC chn= 1 cc= 21 label=“Feedback %3d@(1:6:2)%B”
EVENT_ENC id= 7 fwd_id=LED_MATRIX:7 fwd_to_lcd=1 type=CC chn= 1 cc= 22 label=“ToneRepeat %3d@(1:7:2)%B”
EVENT_ENC id= 8 fwd_id=LED_MATRIX:8 fwd_to_lcd=1 type=CC chn= 1 cc= 23 label=“Mix %3d@(1:8:2)%B”
LEDring-7digits Buttons configuration
DIN_MATRIX n=1 rows=16 sr_dout_sel1=1 sr_din1=1 inverted_row=1 inverted_sel=1 mirrored_row=0 button_emu_id_offset=1001
DOUT_MATRIX n=1 rows=16 sr_dout_sel1=1 sr_dout_sel2=2 sr_dout_r1=4 sr_dout_r2=3 inverted_row=1 inverted_sel=1 led_emu_id_offset=1001
modified ledring patterns for 16 LEDs
LED_MATRIX_PATTERNs
LED_MATRIX_PATTERN n= 1 pos= 0 pattern=1000000000000000
LED_MATRIX_PATTERN n= 1 pos= 1 pattern=1100000000000000
LED_MATRIX_PATTERN n= 1 pos= 2 pattern=1110000000000000
LED_MATRIX_PATTERN n= 1 pos= 3 pattern=1111000000000000
LED_MATRIX_PATTERN n= 1 pos= 4 pattern=1111100000000000
LED_MATRIX_PATTERN n= 1 pos= 5 pattern=1111110000000000
LED_MATRIX_PATTERN n= 1 pos= 6 pattern=1111111000000000
LED_MATRIX_PATTERN n= 1 pos= 7 pattern=1111111100000000
LED_MATRIX_PATTERN n= 1 pos= M pattern=1111111110000000
LED_MATRIX_PATTERN n= 1 pos= 8 pattern=1111111110000000
LED_MATRIX_PATTERN n= 1 pos= 9 pattern=1111111111000000
LED_MATRIX_PATTERN n= 1 pos=10 pattern=1111111111100000
LED_MATRIX_PATTERN n= 1 pos=11 pattern=1111111111110000
LED_MATRIX_PATTERN n= 1 pos=12 pattern=1111111111111000
LED_MATRIX_PATTERN n= 1 pos=13 pattern=1111111111111100
LED_MATRIX_PATTERN n= 1 pos=14 pattern=1111111111111110
LED_MATRIX_PATTERN n= 1 pos=15 pattern=1111111111111111
#7segments Display
EVENT_LED_MATRIX id=9 fwd_id=LED_MATRIX:10 led_matrix_pattern=Digit1
EVENT_LED_MATRIX id=10 fwd_id=LED_MATRIX:11 led_matrix_pattern=Digit2
EVENT_LED_MATRIX id=11 led_matrix_pattern=Digit3
buttons rows
EVENT_BUTTON id=1001 fwd_id=LED_MATRIX:9 type=ProgramChange button_mode=OnOnly range= 01:01 lcd_pos=1:4:2 label=“%2d”
EVENT_BUTTON id=1002 fwd_id=LED_MATRIX:9 type=ProgramChange button_mode=OnOnly range= 02:02 lcd_pos=1:4:2 label=“%2d”
EVENT_BUTTON id=1003 fwd_id=LED_MATRIX:9 type=ProgramChange button_mode=OnOnly range= 03:03 lcd_pos=1:4:2 label=“%2d”
EVENT_BUTTON id=1009 fwd_id=LED_MATRIX:9 type=ProgramChange button_mode=OnOnly range= 09:09 lcd_pos=1:4:2 label=“%2d”
EVENT_BUTTON id=1010 fwd_id=LED_MATRIX:9 type=ProgramChange button_mode=OnOnly range= 10:10 lcd_pos=1:4:2 label=“%d”
EVENT_BUTTON id=1011 fwd_id=LED_MATRIX:9 type=ProgramChange button_mode=OnOnly range= 11:11 lcd_pos=1:4:2 label=“%d”
EVENT_BUTTON id=1017 fwd_id=LED_MATRIX:9 type=ProgramChange button_mode=OnOnly range= 17:17 lcd_pos=1:4:2 label=“%d”
EVENT_BUTTON id=1018 fwd_id=LED_MATRIX:9 type=ProgramChange button_mode=OnOnly range= 18:18 lcd_pos=1:4:2 label=“%d”
EVENT_BUTTON id=1019 fwd_id=LED_MATRIX:9 type=ProgramChange button_mode=OnOnly range= 19:19 lcd_pos=1:4:2 label=“%d”
EVENT_BUTTON id=1025 fwd_id=LED_MATRIX:9 type=ProgramChange button_mode=OnOnly range= 25:25 lcd_pos=1:4:2 label=“%d”
EVENT_BUTTON id=1026 fwd_id=LED_MATRIX:9 type=ProgramChange button_mode=OnOnly range= 26:26 lcd_pos=1:4:2 label=“%d”
EVENT_BUTTON id=1027 fwd_id=LED_MATRIX:9 type=ProgramChange button_mode=OnOnly range= 27:27 lcd_pos=1:4:2 label=“%d”
EVENT_BUTTON id=1033 fwd_id=LED_MATRIX:9 type=ProgramChange button_mode=OnOnly range= 33:33 lcd_pos=1:4:2 label=“%d”
EVENT_BUTTON id=1034 fwd_id=LED_MATRIX:9 type=ProgramChange button_mode=OnOnly range= 34:34 lcd_pos=1:4:2 label=“%d”
EVENT_BUTTON id=1035 fwd_id=LED_MATRIX:9 type=ProgramChange button_mode=OnOnly range= 35:35 lcd_pos=1:4:2 label=“%d”
EVENT_BUTTON id=1041 fwd_id=LED_MATRIX:9 type=ProgramChange button_mode=OnOnly range= 41:41 lcd_pos=1:4:2 label=“%2d”
EVENT_BUTTON id=1042 fwd_id=LED_MATRIX:9 type=ProgramChange button_mode=OnOnly range= 42:42 lcd_pos=1:4:2 label=“%2d”
EVENT_BUTTON id=1043 fwd_id=LED_MATRIX:9 type=ProgramChange button_mode=OnOnly range= 43:43 lcd_pos=1:4:2 label=“%2d”
EVENT_BUTTON id=1049 fwd_id=LED_MATRIX:9 type=ProgramChange button_mode=OnOnly range= 49:49 lcd_pos=1:4:2 label=“%d”
EVENT_BUTTON id=1050 fwd_id=LED_MATRIX:9 type=ProgramChange button_mode=OnOnly range= 50:50 lcd_pos=1:4:2 label=“%d”
EVENT_BUTTON id=1051 fwd_id=LED_MATRIX:9 type=ProgramChange button_mode=OnOnly range= 51:51 lcd_pos=1:4:2 label=“%d”
EVENT_BUTTON id=1057 fwd_id=LED_MATRIX:9 type=ProgramChange button_mode=OnOnly range= 57:57 lcd_pos=1:4:2 label=“%d”
EVENT_BUTTON id=1058 fwd_id=LED_MATRIX:9 type=ProgramChange button_mode=OnOnly range= 58:58 lcd_pos=1:4:2 label=“%d”
EVENT_BUTTON id=1059 fwd_id=LED_MATRIX:9 type=ProgramChange button_mode=OnOnly range= 59:59 lcd_pos=1:4:2 label=“%d”
#next 4 rows
EVENT_BUTTON id=1004 fwd_id=LED_MATRIX:9 type=ProgramChange button_mode=OnOnly range= 04:04 lcd_pos=1:4:2 label=“%2d”
EVENT_BUTTON id=1012 fwd_id=LED_MATRIX:9 type=ProgramChange button_mode=OnOnly range= 12:12 lcd_pos=1:4:2 label=“%d”
EVENT_BUTTON id=1020 fwd_id=LED_MATRIX:9 type=ProgramChange button_mode=OnOnly range= 20:20 lcd_pos=1:4:2 label=“%d”
EVENT_BUTTON id=1028 fwd_id=LED_MATRIX:9 type=ProgramChange button_mode=OnOnly range= 28:28 lcd_pos=1:4:2 label=“%d”
output LEDS
EVENT_BUTTON id=1001 fwd_id=LED:1194 range= 01:01 radio_group=1
EVENT_BUTTON id=1002 fwd_id=LED:1195 range= 02:02 radio_group=1
EVENT_BUTTON id=1003 fwd_id=LED:1196 range= 03:03 radio_group=1
EVENT_BUTTON id=1009 fwd_id=LED:1197 range= 09:09 radio_group=1
EVENT_BUTTON id=1010 fwd_id=LED:1198 range= 10:10 radio_group=1
EVENT_BUTTON id=1011 fwd_id=LED:1199 range= 11:11 radio_group=1
EVENT_BUTTON id=1017 fwd_id=LED:1200 range= 17:17 radio_group=1
EVENT_BUTTON id=1018 fwd_id=LED:1193 range= 18:18 radio_group=1
EVENT_BUTTON id=1004 fwd_id=LED:1210 range= 04:04 radio_group=1
EVENT_BUTTON id=1012 fwd_id=LED:1211 range= 12:12 radio_group=1
EVENT_BUTTON id=1020 fwd_id=LED:1212 range= 20:20 radio_group=1
EVENT_BUTTON id=1028 fwd_id=LED:1213 range= 28:28 radio_group=1
