Newbie question: Layering concept
Cooooool. Thanks man great stuff.
So if I forget about layer/bank switching for the moment loooking at the led feedback problems and use your software and build this baby using a 3 pin duo colored led instead of your 2 leds, I should be able to show next to on/of state a flashing color at each cycle for my ableton clips. (since it sends out vel 0 for stop , vel 1 at each cycle and 127 for on as found in other trhread) . IS this correct or am I missing something ?
I am pretty ok in soldering , just the programmin stuff is not my thing  ;D
Btw if I use normal momentary buttons do I need to bether about this debouncing stuff (no idea what it is but is only mentioned with these funny rubber keyboard buttons.
EDIT: Duhhhhhhh , after looking better at your pics you are using 3 pin leds.  :-X
Is it easy to modify so note on (vel 127) is red (instead of both leds=orange) ??
Please have a look into main.c and decite by yourself, if modifications are easy to realize or not.
Looks like I do have to build the 8x16 monster then …
You can place button/LED matrix in any order you like on your front panel but the wiring must remain the same for any configuration.
Oeps, crossed the line between newbie and idiot i think  :stuck_out_tongue:
Even for a non programmer with the documentation in the code changing led color behavior looks dead easy . Great stuff TK and thanks a lot for you help. Now just wait for the stuff to arrive to start hacking away…
