newbie queistions
Hello,
In the search for customizable MIDI Controller i found ucapps.de. Before i searched lots of Forums and Sites and i just found de doepfer ctm and other doepfer Products, but they offer to low possibilities for a too high price.
So if you could help me find the best and lowpriced possibility for my midi Controller.
I need:
* MIDI Out
* MIDI In
* 18 Fader ( motor )
* 16 Velocity Buttons ( not nessecary )
* 20 Buttons
* 1 Modulation Wheel btw. Joggle Pad
good extensions (not nessecary):
* Light for Faders
* MIDI To USB integrated
If you can place some links for Tutorials and Products or you have good Ideas for this, please help me
And no i wont give up,  and even if its hard and i have to learn, so please help me
Thanks in advance
Martin
i just want to say that i dont need any synth stuff or something, this is just uses as a controller for software in my pc.
If you know where to get cheap faders and buttons, and which of them to use, will be fine if you post them here.
OK , i mentioned, i was to fast and should read a little bit more…
I Searched UCApps and i found the most things i need. But there are some questions left.
I think the midibox64 is the best source for my controller.
So i need :
Core Module
MIDI to USB
Motorfader to Core
please just correct me if iam wrong.  what do i need for lighted faders and buttons if there active ? is there any application that uses this or support this ?
an what to do ?
thanks in advance
Martin
just some minor corrections:
You’ll need
3 x CORE (because of the 18 Motor Faders. One Core can handle up to 8 Motor Fader)
3 x MF Module
1 x DINX4 (for the buttons)
1 x DOUX4 (for LEDs)
1 x USB Module
If you just use 16 Motor-Faders you’ll need only 2 Cores.  - or - if you use fader without motor you’ll only need one Core, no MF and one AIN Module.Think about that.
You’ll need the DOUTX4 module to drive leds for the buttons.
No idea about the lighted faders.
greets
Doc
thanx Doc you helped me out.
so i have a question left.
what motorfaders are best and where to Order them cause i cant find the rs0aon11m froms ALPS at Conrad.at and RS-Components.at cause iam from austria.
someone got experienced in that ?
Just have a look at the german formun. They are doing a order list at the moment.
greets
Doc
greets
Doc
… when the bulk order officially starts, it will be placed in the international forum part.
Thorsten ist testing some different ALPS fader-types before.
Greets, Roger
