I’m planning to build the following modules:
+ MIDI-to-CV for controlling my PPG synth from my MIDI controller and sequencer
+ MIDIbox SID
+ MIDIbox SEQ for arpeggiation and realtime stuff
Is there any overlap in the firmware here, or am I looking at three separate boxes? I did note that there are CV out hooks in both the SID and SEQ, but I usually would want to run separate melodic lines to the PPG. I can’t tell if the firmware allows, for instance, two MIDI channels run into a SID to be assigned one to the SID synth and the other to CV out.
Any insight or suggestions appreciated!
Thanks in advance.
Matt
