Ok, so after reading some stuff on the internets, I think I’ve figured out the optimized PSU thing, at least conceptually. Can you help me confirm some things?
(Remember, any information you pro’s can give me will benefit future newbies because I’ll be writing a detailed, step-by-step guide on the whole CORE+SID construction process.)
Schematic:
To me, the schematic is linear; I visualize it as four separate tracks: 1) +5v (pin 5) 2) GND (pin 2), 3) +9VAC (pin 6), 4) +9VAC (pin7).
From left-to-right, the 5V “track” goes to a switch, the positive side of the 2200 16v capacitor, then to a 100nf cap, and finally out as 5VDC.
The GND track goes to the negative side of the 2200 16v cap, then to the 100nf cap, and out on the other pin, which will be ground.
On the other side, we have the 9VAC (pin 7) track, which goes to the squiggly (~) of the rectifier, out the positive side (+) to the positive side of the 2200 25v cap, then to the 330nf cap, into the input side of the 7809 regulator, and finally out as 14VDC*. [*The + side of the 2200 16v cap (from the 5v track) is connected to the 330nf cap.]
The other 9VAC line (pin 6) goes to a switch, through the ~ side of the bridge rectifier, out the negative side (-), to the negative side of the 2200 25v cap, then to the 330nf cap, and the GND pin of the regulator.
The 14v goes to J1 on the SID and the 5V (and GND) goes to J2 on the CORE (the 7805 regulator on the CORE is not stuffed).
Conceptually, is that it?
Physically, I just mount the components and connect them, as above, as “tracks” I guess. A 5v side and a 14v side.
By the way, I’ve been using this site as a guide:
http://www.danielprice.org.uk/synth-diy/sid_2.htm
If I’m right about all this, it’s a breakthrough because I had never even looked at a schematic, picked up a multimeter, or scorched myself with a soldering iron before this project.
Thanks.
-d
