you need an own C64 psu for your mains voltage in your country!.. don’t use that european 220V!!
the bottom pin should be ground, all the other like in description here:
http://www.c64-wiki.de/index.php/Netzbuchse (german) - but get sure -> take a measuremeter and check Voltage of pins between ground. but do it with a steady hand. test it only with an “canadian PSU”.
it’s best solution to use the optimized PSU schematic with one psu.
best you connect the few parts of C64 optimized psu schematic and connect core to sid board. then check the voltage at IC, without stuffing SIDs.
yes you need a DINX. Connect one rotary encoder and connect ground like in description of DINX.
If you hold off for a short while, maybe the right switch will become available and you can save yourself the trouble of desoldering it and of killing a c64
I also need help with a PSU question but I also have two things to offer. Can I still use the optimized psu with a single sid solution? Still doing exactly was it say i.e. remove IC3 from the core?
Nevermind read the walkthrough closly again. I can use this for one SID. Enjoy the switches ;). Oh I am also blogging about my progress for anyone who wants to take a look. www.frishkorn.net.
