I have very little electronics experience, but I am learning now.
I am reading, and I will continue to, but I have a question to which I cannot find the answer anywhere -
is the ceramic cap damaged if you bend the leads to closely to the ceramic? i cracked the legs (where the ceramic stops), and I am wondering if it will affect the funtionality. Is there a way to test if mine is ruined?
the final result should be a MIDIbox SiD, if all goes well.
If you only cracked the ceramic part (a little piece came of or similar) - that´s no problem at all. As long as *the wire* is not damaged (!!!). Anyhow measuring the resistance of it is indeed a good idea, if it got no short (meaning a resistance higher than 100 kOhm) everything´s just fine. If it´s less that value I would abandon it also.
