I purchased a lcd from crystalfontz.com (http://www.crystalfontz.com/products/2002a/index.html#CFAH2002AYMCJP) and turns out it uses negative voltage…when i connect it to the core i get 2 rows of blocks…ive uploaded the mios sysex and pinged it to make sure it uploaded and was successful. now since it uses negative voltage should i even get anything to display besided blocks?
Now it’s being quite a while since I’ve used a display that required negative voltage for LCD. However if I did eye the datasheet correctly it doesn’t need much of negative voltage, only under 1 volt or so, depending on the ambient temperature. So adjusting this on some direction does not have any affect on having black rows or how is it?
Right now I dont have a way to convert to negative voltage..although I have ordered an inverter…I was thinking of just ordering another lcd with it built in but wouldnt something display anyways or am I wrong? I did adjust the contrast so blocks appeared.. I probably should go over the soldering again
Can’t say for sure-- but your display CFAH2002AYMCJP doesn’t seem like the one needing a negative contrast voltage…but your probably experiencing some other problems== not that I ever had those,
as far as i know, you shouldn’t be getting those blocks if you need a negative voltage. i have a negative voltage lcd and the blocks don’t appear without a negative voltage.
Did re-read the datasheet and according to the need of negative VO the datasheet says:
Supply Voltage For LCD = VDD - VO = -0.3…+7V
Which translates to:
VO = VDD - VLCD
And while your VDD is +5V, the VO should be within range of:
5V - (-0.3)V = +5.3V and 5V - 7V = -2 V
Now these are the maximum values that should never be exceeded or it will break down the display.
However the datasheet also suggests that the typical VLCD would be 4.5V @ 25C temperature, so the typical V0 would be 5V - 4.5V = +0.5V
Did I get it all wrong now? Someone? This is how I interpret the datasheet but something can be lost in the translation
BTW: A good trick to generate the negative voltage (if needed) is also to use a standard MAX232 or similar RS232 converter. Just feed logical 1 to TX input and voilà , you have generated negative voltage on other side. No need for external inverter, specially if you are working with a design that already have RS232 interface (chips tends to have two RX/TX pairs).
Hi erverbody!
Couldt anybody explain me how I have to connect my display to the MAX232?
