I know it’s not chiristmas…
QBAS did me some superb code for a 9 by 18 matrix. However, I want to add other function to the code (as one does), but QBAS is an assembly man, and I’m not.
Am I right in saying that the main.asm file in the assembly version should become the mios_wrapper.asm in the sdcc skeleton, and just copy all associated files into the mios_wrapper folder OR am I just as stupid as George Bush? :
Project nearly finished, so photos etc on the way…
Mark.
George Bush isn’t stupid and neither are you… But your guess was about as right as he is a good speaker ;D
You’ll need to wrap the ASM that qbas sorted out into the main.c, using techniques like those at the How to mix C and ASM wiki page, or include the ASM file in your C project, using techniques like the using assembler in C - question about _ in front of macro names post
Feel free to post/PM/email me for a hand.
erk-- a lot of asm- lost, totallty lost.
In the ucaaps there are great example blocks of code, like how to send cc values when a pot has been moved. Is there an ASM version of this anywhere. All I want to do is assign 20 slide pots set values, and never have to touch them again.
AAny ideas?
Try this mate. As stolen from mb64 like a cowardly pirate, yargh.
;; This function is called by MIOS when a pot has been moved
;; Input:
;; o Pot number in WREG and MIOS_PARAMETER1
;; o LSB value in MIOS_PARAMETER2
;; o MSB value in MIOS_PARAMETER3
USER_AIN_NotifyChange
;; convert 10-bit value to 7-bit value
rrf MIOS_PARAMETER3, F ; value / 2
rrf MIOS_PARAMETER2, F
bcf MIOS_PARAMETER2, 7 ; clear 8th bit
;; now: pot number in MIOS_PARAMETER1
;; 7-bit value in MIOS_PARAMETER2
;; CC Ch 0
movlw 0xB0
call MIOS_MIDI_TxBufferPut
;; CC# = Pot#
movf MIOS_PARAMETER1, W
;; CC Value = Pot Value
movf MIOS_PARAMETER2, W
Cheers Captain Hook. That would be the very thing!!! ;D
