Could not find my answer doing a search, so I thought I would ask -
How do I format the Bankstick in my MB808. When I FIRST plugged it in, it went though the formatting routine, but some of the chips failed (due to poor solder joint). Now that it’s fixed, I want to RE-Format the Bankstick so that it’s properly initialized. When I start up the MB-808 it simply does a quick check to see if it’s there, but does not format it. I’ve tried re-arranging the chip order. I’ve also tried re-flashing the HEX file for the MB808. But no luck. It will not re-format! I can’t find it as a Utility anywhere in any of the menus. I thought perhaps its a “hold down a button on startup” type thing, but not sure which. Do I need to pull the chips and erase them in an eprom programmer? I hope not, I don’t have one! ANY help would be GREATLY appreciated!
Thank you,
Ben
