I attempted to name the “unnamed” Mixer Map #1 to “MultiOne” by removing the sdcard, putting it in a PC card reader and editing the session MBSEQ_M.V4 file.
The name changed o.k, but the ports changed from all “Def” to USB1 and USB4 and all the channel assignments to 1. The page 3 (Prg Ch) fields all contained the values that should have been the midi channels.
The Page 4 Volume settings had the values of the Prg Ch. etc,etc.
So I corrupted the mixer maps file.
Is the correct way to edit these files documented anywhere?
I just powered up the SEQ and (without changing the firmware) all the settings in my corrupted MBSEQ_M.V4 were restored including the names going back to “unnamed”.
I’m glad this happened but somewhat mystified.
Does the sequencer restore a backup in the case of corruption? I’m convinced it is the same session file.
The cursor caused problems with certain LCDs in the past, therefore I haven’t considered it in the software anymore.
It would also be too cumbersome to make it only optional, because supporting two different display options is really a nightmare for testing UI enhancements!
