my SID has become alive and made it’s first sounds. ;D ;D ;D Just needed to tell you all. 8)
Next step is to build a case.
Awesome! I just got the last major bug worked out of mine, thanks to the help of this forum (TK, especially). This is an amazing project to be a part of!
Best of luck,
Charles
Congratulations! Did everything go smoothly?
Thanks to both of you,
Nearly
The lack of my soldering practice leaded to two sucked off soldering-pads on the core-module (I’ll never use a desoldering pump again. learned that for life). :o Needed three additional wires to patch this.
The second problem was a little misunderstanding of the optimized-psu-schematic, so I busted the regulator. In the schematic the pins of the 7809 are numbered 1,2,3 from left to right. In the datasheet of the 7809 (which I refered), pin 3 is the middle one. So I connected them the wrong way and grilled it. Good to have some spare parts. ![]()
Ouch, I better look out for that one when I start putting together mine - my local electronics place could only offer a 7809 in 100mA, and i’m not going mail-order for a single part!
100mA? Should be ok for one SID, but more … I don’t know.
I’ll do a mailorder some parts end of the month at Reichelt. If you want I can send you a 7809.
Mike
It’s ok - my girlfriend’s going shopping in town tomorrow and there’s a maplin there, i’ll get her to get me a 2A version. A 78S09 should do the job shouldn’t it?
2A is more than enough. Should work.
Mike
That’s what I thought - having no idea on the power draw of the whole thing I couldn’t be sure, but 2A sounds plenty big enough for a CORE, SID, DIN, DOUT and PLED, even if i chose to upgrade to 4 SIDs in the future.
The 7809 is used only for the 14 volts needed by the sid-module, so 1A should be enough even with 4 sids.
Mike
