Well.. this is where the projects at; Got one LCD to fix (and some logo decals to add on the case outers) ..then its done with ![]()
After abit of soldering.. all the leds, functional & brought to the same brightness levels..
This is the original panel design for my midi box seq…
© Artesia 2005 ![]()
My less than tidy wiring & somedetails of internal construction.. given that it doesnt see much light of day.. i dont try to hard here:
Yup.. made with recycled pentum spec pc cases..
Drying front panel ‘decals’:
the lines on the panel dont really go like that
its some funky interference pattern from image sizing…
Bare chassis.. front panel to be added on top..
Well.. some progress has been made with further construction; waiting on the nice people at lazertran to post on some of the inkjet compatable stuff (works in lasers too). This is the sub chassis which all the components & boards mount to; the front panel with all the (nice) graphics design will sit above this to provide a tidy finish… also the case shell will completely enclose this element.. keeping all the clutter & fixings on this inner shell element ![]()
* upper row of grey buttons are diy ..Change of design from the render.. …made by flattening the top of some plain grey buttons with a file, drilling a hole in the middle & gluing some reclaimed speckled plastic to the top …results in a translucent button with a ‘sweet spot’ in the middle.. looks fun - will wire up for effect sometime soon…
(Should i put the following here ? ..hmm, ah well here it goes anyways..)
Progress has been slow here in getting these boxes built and finished ..as other little projects have cropped up and completed.
Of late i was lucky enough to get an abandoned, trashed Leak Stereo 20 Valve amplifier & matching 2030 speakers from the 1960’s.
The speakers, although a dosmestic model …where based on the same 3 way technology; with a aluminum 10mm foam sandwich 10" woofer - used in their popular studio bound, sleeker.. bigger sister speakers.
Took some work to restore this lot… The speakers needed the rear spiders reattaching to the magnet & carefully centering up… but worked fine afterwards …damp got to the spiders over the years i guess. The amplifer needed a full overhaul, the chassis was repainted a curious pearlescent purple/blue ..which changes colour and tint depending on lighting (difficult to photograph !); As for components… all the capacitors were replaced & the resistors with modern high voltage metal film resistors.. DONT use ‘new old stock’ caps & Resistors …they are inferior & have usually deteriated to a worse state than that of the ones already present. Oh.. and new valves were needed… four ‘new unused, old stock’ Mullard EL84’s from ebay on the output end & three ECC83 Electro Harmonix’s on the in stage. …and the finishing touches were decent quality gold contact speaker & line terminals + a mains switch & a new solid base under the amp.
If you happen across one of these… or any other half decent valve amp… RESTORE IT ! …you’ll not regret it & even if you dont like em’ …theres plenty of people out there who will pay top dollar for a tidy one…
Iv’e always wondered what the fuss was all about with valve amps… and well ..the first time i rigged this one up …er Woa ! ..they do indeed sound nice
..very clean (and with modern caps+ res’s) 'n quiet… + the top end is clear.. but not harsh…
The 14-16w or so per a channel really does go alot further for some reason ..they can give a 50wpc amp a run for its money. At that, they really do sound shed loads better than most half grand transistor amps… had this up against a decent studio grade amp… and the Leak was far nicer to listen to ![]()
Quick note …there are afew el84 based designs out there on the web; if anyone wants to have a crack at building one from scratch …go ahead …just keep in mind that going above these power ratings with valves is generally un nessursary & it gets far more difficult to keep em sounding clean without buying silly expensive transformers ..and so on ![]()
A quick, and marginally blurry shot of the end result…
Sort of what the amp used to look like …except my one was scratched up & dented like crazy… Eew, that muddy gold colour !
A Hi-Fi world article about the Leak Line of valve amps:
http://www.hi-fiworld.co.uk/hfw/oldeworldehtml/leakstereo20.html
A Leak Stereo 20 restoration website ..proved useful to me…:
http://www.geocities.com/stereo20/
About the Leak sandwich speaker technology…:
http://werple.net.au/~kiewavly/sandwich.html
