well after speaking with a few members i have decided to build one of thorstens midimons with the mtc display also.
i will have a custom case made but i also want to insert into the case the insides from a contour shuttle pro controller then i will have a really nice mtc display and control surface unit.
now this will be my very first build of a project here, im very good with a soldering iron, i have 3 different irons from standard all the way to fine pitch and i also have a surface mount iron set with vacum pump.
its been a long time since i did eny form of electronics work so im getting back to it very slowly and this will be a good starting point.
now in the midimon thread i didnt see if there is a pcb available for the main controller or not, if not do you have one thorsten that i can give to someone to have made? a circuit shcematic for making a pcb? also is there a chip on the board that would need an external programmer to insert some custom operating code into? if so is it possible to get someone to do this for me? i know that the mtc displays board was a prototye board and thats ok i can get them but the main control baord i dont know what was used for that as theres no information.
im hoping to get as much info and pictures etc as i can so i get things right first time, its a project im looking forward to.
also on this picture you see the front of the board but there isnt a picture of the rear, so i cannot see how the connections were made. is therea picture or can you take a picture of the rear for me thorsten please?
if you guys can give me as much help as possible i can get parts ordered and get on with a build.
also i am wondering if i can change the green lcd display for a blue one? if there is a blue equivalent (do you know if there is one thorsten?) something similar to this display here http://shop.tuxgraphics.org/electronic/detail_lcd_blue.html
many thanks guys, im looking forward to building this.
