My 1st MidiBox64 Build, need guidence.
I’ve never built any tupe of USB/Midi controller. I am pretty crafty and very familiar with soldering. After seeing some stuff on other forums I decided to dive in and build something.
I ordered:
25 Arcade Buttons from DJTT
1 Core 32 Parts and Board from SmashTV
2 AIN from SmashTV
2 DIN from SmashTV
2 DOUT from SmashTV
2 Banksticks from SmashTV
40 Pots from AllElectronics
I’m having trouble with choosing buttons besides the Arcade ones.
I would like 32 buttons smaller than the Arcades that light up when pressed to let me know they are active. I got a Multimec PDF catalog but there are a lot of choices and I want to make sure I get the right buttons.
I am also not 100% about an LCD screen.
Any specific ideas would be greatly appreciated. I am using this set up to control Ableton Live and Traktor.
Here is a picture of my current set up and a picture of what I am shooting for. May be ambitious for a first build but I am paitient and determined.
I eventually want to build this into one solid console as a case for easy transporting and set up.
Hey SOLO its kaleaf from the djtt forum,  I think you got the wrong core and you need the regular one.
also
http://www.mouser.com/catalog/catalogusd/639/1589.pdf
thats mouser catalog for pushbuttons tons of stuff in there
look for momentary switches with solder points (lug)  or surface mount if you want to put them on a pcb breadboard.
I will be at a festival untill 10/19 but I would be glad to help you look for parts when I get back in a few days, I need to get more parts also.
also
OK so I finally got my PCB’s etc in the mail. Took a while. You think I got the wrong one? The core 32 from Smash TV???
I got the Core32 PCB and parts kit from here, http://www.avishowtech.com/mbhp/buy.html
The reason kaleaf thinks it’s the wrong core is that there’s few/no apps for the mios32 yet. So you’ll either have to code your own or wait till it happens :wink:
Quick Question,
I am making a shopping list of things I will need. I pretty much understand everything except getting a power supply.
Is the power supply referring to like a 9v wall plug? Or what? What is the specific purpose, how will I be using it etc???
A 9V wallwart will do just fine. How will you use it? Plug it in the wall? The purpose of a power supply is to, erm, supply power. Try removing the power supply from your PC and see how well it runs :wink:
