I read in the lcd hardware section about putting multiple clcds onto the Ng is possible in this link : http://www.ucapps.de/mbhp/mbhp_lcd_6x2x20_mios32.pdf
Question:
Is it possible to attach 16 X 1 line 3 digit clcd’s to the NG and have each one, via code linked to either a rotary pot or encoder in its value state? (would rather go this route)
i understand an easier option is to either use oled displays or a single 2x40 with padded values spaced equally however, thi cldcd route is something i really want to try out
I want to build a vintage plugin controller and it has 16 3 digit clcds in its on screen display.
The other reason for the clcds is that i want the old red segments.
the other option i thought of was using one 2x40 clcds and padding them out so there are 4 sets of values per line but each value is padded equally and shows the 0-127 value above each pot/encoder
now I understand the use of the padding for a name and the id-value, I just need a poke in the right direction as to which is the better option.
