I’m in love with the MB808 and intend to build one when it comes out again. I also am interested in using it as a set of triggers for my analog modular synth. It would be heaven to combine the MPC USB interface with the Core/etc. and use it to generate at least 8 CVs for volume/velocity, and perhaps another 8 for controllers, to impart MPC style (16 levels, pressure for variable volume press rolls, a real-time/sequenced slider to output a CV to control decay time, perhaps the real-time Erase key) upon the 808 and the modular. (Edit: I know that I’d then need 8 VCAs, but with the quad SSM2164 lurking around, that’s not very scary.)
I’m a complete newbie to your technology, but sense that this is possible, whether as a stand-alone system or as an addition to the MB808. I would vastly appreciate any insight into making this a reality. Cheers on one of the most exciting systems in years!
You had me extremely excited when i read that, only to realise you meant to say MPD!
Sounds like a cool idea you have the 808.
Oops, modified my post to reflect that. Sorry.
The thing that I am unclear about is the nature of the software that is available for users, and what can be added or changed, and by whom. I’ll figure it out ;D
Everything’s available, and open source, so anyone can change or add as much as they need - just don’t forget to share it when you’re done
You might like to look at the MIDIbox CV or Analog toolbox or MBSID (without SID chips), to use as a CV engine which will convert incoming MIDI messages to analog control.
