This is sort of a continuation of the “Digikey Quotes” topic. I had to change to a new topic, firstly because I’m not going to buy from Digikey, but from Mouser; second of all I am very green at component picking so I was wondering if I could get any comments for the PIC Burner Mouser order list I assembled?
One problem left (I went through several in the other topic): I can’t find LPT connectors anywhere, even browsing through the i/o section of the site. Does anyone know what it would be under?
MBHP BURNER Orderlist (last update: 01-2007)
| Loc. | Description | Qty | Mouser Part # |
| - | IC-Socket for PIC | 1 | 571-3902625 |
| - | IC-Socket for 74HC14 | 2 | 2-641609-1 |
| - | 74HC14 (6 x Schmitt Trigger) | 2 | 512-MM74HC14N |
| - | Transistor BC337 | 1 | 2N3904TA |
| - | Resistor 10 kOhm | 3 | 291-10K |
| - | Resistor 1 kOhm | 7 | 291-1K |
| - | Resistor 470 Ohm | 3 | 291-470-RC |
| - | Resistor 220 Ohm | 1 | 291-220 |
| - | Trim Pot 2.2k | 1 | 3362R-1-222LF |
| - | Diode 1N4148 | 1 | 78-1N4148 |
| - | Diode 1N4002 | 1 | 821-1N4002 |
| - | Voltage Regulator 7805 (in TO92) | 1 | 512-LM7805CT |
| - | Voltage Regulator LM317 (in TO92) | 1 | 512-LM317LZ |
| - | Ceramic Cap 100nF=.1uF “104” | 6 | 80-C412C104K5R |
| - | Polarised Capacitor 100 uF (min. 35 V) | 1 | 140-XRL35V100-RC-TB|
| - | Polarised Capacitor 10 uF (min. 20 V) | 2 | USR1E100MDD |
| - | Bridge Rectifier | 1 | 625-W08G |
| - | 25 pin LPT connector, male | 1 | ??? |
| - | Two “Clips” for 9V Batteries | 2 | 534-68 |
Not included:
Green Power LED
Yellow Vdd LED
Red Vpp LED
Two 9V batteries
1:1 LPT cable (male/female)
