Motorfader connection
Hey
I just wonder about the connection from the motorfader driver board to the fader. ???
Is output M11 positive and M12 ground to move the fader towards max level.
M11 ground and M12 positive to move the fader towards min level.
or is it the other way around.
As I am making a PCB board to mount my fader on, so I need to know it.
Kent
It depends on the fader, so best way would be that you try it before. Just connect the fadermotors with a flexible cable, so that the wires can be exchanged if necessary.
Hey Thorsten
I don’t fully agre about the type of fader.
I know how my fader works, but how does the PIC work.
The fader has VCC in one end, the max. end and GND in the other, min., so the voltage out will get higher if the fade move toward the max end.
What I need to know is, If the PIC need to move the fader towards the max end will the VCC come out of M11 or M12.
By knowing that and testing the motor polarity I can find out how the make the connection on the PCB.
Thanks
Kent
Ok, I will open the case of my MIDIbox LC in order to find out which polarity I used (documentation will be published in the next days). But it doesn’t really matter. As I wrote: you just only have to exchange the two cables to the motors if you choose the wrong polarity. In worst case - if you finished your PCB and didn’t use flexible cables - I could build an option into MIOS which allows to invert the polarity via software. :wink:
Faders: Vdd should be on the upper end, so that the analog pin receives +5V when the fader is at max position.
Hey Thorsten
Thanks again for your answer.
I just the case, I am in the progress of making a PCB,
so I need to make it right, but a software reverse function will do the job.
Kent.
PS. for me VCC = Vdd
For CMOS designs it’s better to take Vdd (=drain supply voltage)- however, just another issue :wink:
I finally found the file in an old backup:
http://www.uCApps.de/mbhp/mbhp_mf_interconnections.pdf
Hey Kent,
  Why not put  jumpers in your PCB design, to allow reversal of the polarity?
 good luck with it!
 from Steve
