"momentary" led buttons or not ?
hello
the midibox run with momentary type led buttons (push and keep push =ON , release =OFF)
or not “momentary” type (push =on , re-push =off) ?
thanks
ww
momentary tact switches
hi! you’ll find your answers in the DokuWiki parts FAQ:
http://www.midibox.org/dokuwiki/doku.php?id=parts_faq
and on the wiki page of Wilba’s 6582 you’ll find also an example with name, manufacturer and part number of a possible switch:
MB6582 CS parts list
In the midibox tutorials may be you read about a special feature which will be assigned to the buttons : Toggle value - Send learned value with the first keypress, send zero value with the second keypress.
thanks guys ! ! !
seen this good page
only an info about button with led : if i use momentary button (as suggested )
when i push the button the core receive the command and led go on with light,
but:
when i release the button the command and the led stay in on “status” until i re-push the button
or go in off ?
thanks in advance
ww
