Modifying mios32/apps/sequencers/midibox_seq_v4/core /seq_ui.c
Hello,
I try to remove the view step of the step button.
I suppose replacing:
this:
static s32 SEQ_UI_Button_StepView(s32 depressed)
  //  static seq_ui_page_t prev_page = SEQ_UI_PAGE_NONE;
  // also used by seq_ui_stepsel
  static seq_ui_sel_view_t prev_sel_view = SEQ_UI_SEL_VIEW_NONE;
  if( !depressed ) {
    prev_sel_view = seq_ui_sel_view;
    seq_ui_sel_view = SEQ_UI_SEL_VIEW_STEPS;
    seq_ui_button_state.TAKE_OVER_SEL_VIEW = 1;
    if( ui_page == SEQ_UI_PAGE_MUTE || SEQ_UI_PAGE_PATTERN || ui_page == SEQ_UI_PAGE_SONG )
      SEQ_UI_PageSet(SEQ_UI_PAGE_EDIT); // this selection only makes sense in EDIT page
  } else {
    if( !seq_ui_button_state.TAKE_OVER_SEL_VIEW )
      seq_ui_sel_view = prev_sel_view;
  if( seq_hwcfg_button_beh.step_view ) {
    if( depressed ) return -1; // ignore when button depressed
    if( !seq_ui_button_state.STEP_VIEW ) // due to page change: button going to be set, clear other toggle buttons
      seq_ui_button_state.PAGE_CHANGE_BUTTON_FLAGS = 0;
    seq_ui_button_state.STEP_VIEW ^= 1; // toggle STEP_VIEW pressed (will also be released once GP button has been pressed)
  } else {
    // set mode
    seq_ui_button_state.STEP_VIEW = depressed ? 0 : 1;
  if( seq_ui_button_state.STEP_VIEW ) {
    ui_stepview_prev_page = ui_page;
    SEQ_UI_PageSet(SEQ_UI_PAGE_STEPSEL);
  } else {
    if( ui_page == SEQ_UI_PAGE_STEPSEL )
      SEQ_UI_PageSet(ui_stepview_prev_page);
return 0; // no error
by this:
Also i suppose i have to replace this:
SEQ_LED_PinSet(seq_hwcfg_led.step_view, ui_page == SEQ_UI_PAGE_STEPSEL || (selbuttons_available && seq_ui_sel_view == SEQ_UI_SEL_VIEW_STEPS));
by this:
SEQ_LED_PinSet(seq_hwcfg_led.step_view, ui_page == SEQ_UI_PAGE_STEPSEL ));
Als is there a way i can test the code without uploading it into the seq?
Thanks in advance,
