I am having trouble compiling anything using the eeprom module in mios32. Any code that doesn’t use the eeprom library compiles correctly, but even the eeprom tutorial doesn’t work. I am on OS X 10.7.
Aarons-Macbook-Pro:025_sysex_and_eeprom aaron$ make
rm -f project.hex
make: *** No rule to make target
project_build/~/svn/mios32/trunk/modules/eeprom//eeprom.o', needed byproject_build/project.elf’. Stop.Aarons-Macbook-Pro:025_sysex_and_eeprom aaron$
The next problem, which I think is part of the same issue, is that I can’t include the eeprom header in my own apps using include <eeprom.h>.
Aarons-Macbook-Pro:ArtNet Node aaron$ make
rm -f project.hex
Creating object file for app.c
app.c:21:20: fatal error: eeprom.h: No such file or directory
compilation terminated.
make: *** [project_build/app.o] Error 1
I’m not sure if it’s a makefile issue, but just in case, here is my makefile.
# $Id: Makefile 502 2009-05-09 14:20:30Z tk $
# following setup taken from environment variables
MIOS32_PATH = ~/svn/mios32/trunk
MIOS32_BIN_PATH = ~/svn/mios32/trunk/bin
MIOS32_GCC_PREFIX = arm-none-eabi
PROCESSOR = LPC1769
FAMILY = LPC17xx
BOARD = MBHP_CORE_LPC17
LCD = universal
# Source Files, include paths and libraries
THUMB_SOURCE = app.c
# (following source stubs not relevant for Cortex M3 derivatives)
THUMB_AS_SOURCE =
ARM_SOURCE =
ARM_AS_SOURCE =
C_INCLUDE = -I .
A_INCLUDE = -I .
LIBS =
# Remaining variables
LD_FILE = $(MIOS32_PATH)/etc/ld/$(FAMILY)/$(PROCESSOR).ld
PROJECT = project
DEBUG = -g
OPTIMIZE = -Os
CFLAGS = $(DEBUG) $(OPTIMIZE)
# Include source modules via additional makefiles
# sources of programming model
include $(MIOS32_PATH)/programming_models/traditional/programming_model.mk
# application specific LCD driver (selected via makefile variable)
include $(MIOS32_PATH)/modules/app_lcd/$(LCD)/app_lcd.mk
# common make rules
include $(MIOS32_PATH)/include/makefile/common.mk
Any ideas?
