MIOS V1.9 released
After a lot of beta testing (which was hopefully enough) I just have released MIOS V1.9
See the ChangeLog for details:
http://www.ucapps.de/mios_changelog.html
The biggest benefit of the changes: more memory free for applications -> more features! :slight_smile:
An update to the new MIOS and Bootloader version is strongly recommented, since newer releases of MIDIbox SID/SEQ/FM/64/64E won’t be compatible to MIOS V1.8 and lower!!! They will get use of the upper 1k block, which was allocated by bootloader V1.1b before
In addition, following programs have been updated:
  • skeleton_v1_9: contains new copyright message
  • sdcc_skeleton_v1_9: contains new copyright message, function declaration for MIOS_IIC_SendByte changed
  • change_id_v1_9: allows to change the MBHP_IIC_MIDI ID in the ID header
  • midi_router_v1_0: the MIDI router project, which is unfortunately not documented yet, but which runs stable since weeks. :slight_smile: It could also be interesting as example, how to combine C and assembly code
AWESOME!!!
In awe of your work as always :smiley:
[glow=red,2,300]THANKS TK!![/glow]
Edit: WOW wow WOW I’ve just read a bit and WOW TK you really have been busy!
YOU ROCK, TK!!!
now i just need to update my 5 or 6 cores… grrrrrr    :slight_smile:
thanx,
gb
Just finished reading the changelog - this is GREAT!
Thanks TK! As always, amazing work!
-drin
Thanks,
now I know what I am going to do in my Easter holidays…  ;D
Best regards, ilmenator
wow,
the c function reference addition is also very welcome!
Thanks TK!!
:slight_smile:
i’ve burned the new bootstrap on a fresh PIC and uploaded the new mios without problems.
great thanks TK!
I guess the burning question here is, will SmashTV now be including MIOS 1.9 on his pre-burned pics??
a BIG THANKS for T.K. :-*
Yes.  :slight_smile:
huh? I thought you only had the bootloader on it?
Impressive customer support :wink:
Whoops I mis-spoke, I meant the chips will have the new bootloader only.
Reason: If a builder can’t get MIOS loaded, not too likely to get an app loaded either etc…
Best to get the MIDI ports to a known-working state early on, MIOS pre-loaded would make that process harder.    :wink:
Best!
Smash
Best to get the MIDI ports to a known-working state early on, MIOS pre-loaded would make that process harder.    Wink
this i agree with, as murphy said “a $3000 picture tube with save a 1/2 cent fuse by blowing first”
Is there a way to know wich version of the bootloader is installed ?
It’s described in the README
if you want to determine it from the program side, just do a table read at 0x404, if the two bytes are 0x11, 0x47, bootloader v1.2 is installed
