mios upload problem
hi,
i just finished building a midibox64 with kits from mike’s electroniks. running mios studio, i get the upload request every 2 seconds:
00000002082380 ms | Sysex message: F0 00 00 7E 40 00 01 F7
00000002084274 ms | Sysex message: F0 00 00 7E 40 00 01 F7
the problem is that when i try to upload, the requests keep coming, and i get this error:
Sending block 00000000-000000FF
Error: Received unexpected Upload Request
searching through the forum, i came to the conclusion that maybe my device ID is 1 instead of 0?
i found this solution:
it seems that the device ID is 0x70, however, there is an easy way to fix this.
Just load the mios_v1_7.hex into Serge’s SysEx loader, set the ID to 0x70 and upload the file
Thereafter upload the change_id application, it will overwrite the ID field with zeroes
unfortunately, serge’s sysex loader does not appear able to handle hex files. is there anyway to specify the device ID with mios studio?
thanks for any tips,
greg
oops, i guess maybe my device ID is actually 0. i changed it to 1 in mios studio and got unexpected sysex error:
Received unexpected MIOS SysEx message = 00007E400001F7  expected = 00007E4001
i went back over the forum posts and concluded that my device ID is actually 0.
any other ideas? i tried replacing the optoisolator, but i still get the same results. i’ve done the midi troubleshooting tests. they all pass except i’m not seeing midi getting to the Rx line.
thanks,
greg
yes, the device ID of your core is 00.
Which MIDI interface are you using?
Are the In/Out ports routed correctly in MIOS Studio?
And is TEST INOUT1 (see troubleshooting guide) really passing?
i am using a m-audio midisport 2x2.
here are my test results:
TEST IN1: passed
TEST IN2: passed
TEST IN3: FAILED
TEST IN4: FAILED (but led lights when connected to pin 8)
TEST IN5: passed
TEST IN6: FAILED (led does not light ever)
TEST IN7: passed? open voltage = 4.87, closed voltage = .05
TEST INOUT1: FAILED (nothing received back into midi monitor)
seems that midi is not reaching the rx pin?
thanks,
greg
Ok, MIDIsport 2x2 should work perfectly
Btw:
[/code]
which file are you trying to upload? Because this address range should neither be used by MIOS, nor by any MIOS application
The bootloader is located at 0x0000-0x03ff, it cannot be overwritten via MIDI...
You have to upload pic18f452/midi/mios\_v1\_9f\_pic18f452.hex of the mios\_update\_v1\_9f.zip package
This is the only .hex file you need to upload of this package (thereafter you can start to upload an application)
However, this isn't the problem here...
The result of TEST\_IN6 indicates, that this is neither a PIC, nor a MIDI interface, but a general (electrical) issue. It seems to be a bad soldering joint between MIDI In port, the Rx pin or the circuitry around the optocoupler. Without a scope, only visual checks will help here (I guess, that you've already checked the supply voltages...)
thanks for your help. i’ve inspected and reheated several solder joints, but i will go over it a second time and report back.
fixed!
i reheated solder joints, and there was one that looked like it may have been bridged to an adjacent trace. i also replaced the socket for the optoisolator.
thanks for your help!
