MIOS_TIMER_Init prescaler question
hi all,
based on which criterias should I choose a timer prescaler? is there some performance
advantage/disadvantage?
in the documetation, this example is shown:
// we want to setup the timer with a frequency of 500 Hz = 2 mS
  // prescaler 1:1 should be used
  // calculate the required number of clocks for this period:
  // clocks = period / 100 nS = 2 mS / 100 nS = 20000
  // therefore:
  MIOS_TIMER_Init(0x00, 20000);
  // now the Timer() function is called every 2 mS!
why not take a prescaler of 1:2 and set the period to 10000?
this
I’m using 1:1 prescaler in this example, so that the period time is easier to calculate.
1 mS == 10000
Maximum value for 1:1 prescaler is 65535 = 6.5535 mS
got the point?
At application level, there are no real advantages/disadvantages when using higher prescaler values. Just select a prescaler which fits your needs
ok, I see, thanks
