It would be very helpful if you could compile a special list for MIOS users (it could be included under HOWTOs->mios_tables.inc) - the coding is simple when hexadecimal numbers are used:
B stands for “MIDI controller”
0 for the MIDI channel (0-15 == channel 1-16)
the next 7-bit value indicates the MIDI controller number
Note On events: use 9 instead of B
Note Off events: use 8 instead of B
the next 7-bit value indicates the note number
If the two bytes of a table entry are matching with the received MIDI event, the USER_MPROC_NotifyFoundEvent function will be called by MIOS. The first two MIOS_PARAMETER[12] variables contain the same bytes like the appr. table entry, the third variable (MIOS_PARAMETER3) contains the CC value (on MIDI controller events) or the velocity value (on note On/Off events)
Special case: if a Note On event with velocity == 0x00 has been received, it has to be handled like a Note Off event (see MIDI specification)
