Hi, LIST.
Question… I’m having some trouble getting my computer to see the CORE_R4.
I run MIOS studio with out a problem (excellent work, thank you for this wonderful tool!) , however,
I’m wondering why sometimes i have solid lines connecting devices, and sometimes dashed?
My guess is that dashed lines represent connections that should be, and solid lines are connections that are actually working. Is this the case? I can’t seem to get the solid line anymore.
I’ve tried several different devices as a USB->MIDI interface, and none of them seem to connect correctly.
Using an oscilloscope, I can verify that the CORE-R4 is definitly transmiting a chirp (upload reqeust) every two seconds. Here…
BTW, if someone wants to add this capture to the WIKI for troubleshooting, that would be cool…
and, this isn’t really needed here, but this is a capture of the clock…
again, if this can be added to the WIKI for troubleshooting, maybe it can help someone else…
I’ve tried the Lexicon Omega interface, Tascam US122, and the Evolution UC-33e, all seem to be doing the same thing, not passing MIDI thru properly.
Advise?
Thanks a bunch,
Jason D
********UPDATE***************
Midi-OX can see the chirp!!
can MIDI-OX be used to upload the MIOS hex?
