The new MIOS programming platform is finally available for public after almost 6 months of continuous work.
Big thanks to everybody who contributed! ![]()
Basically it unifies the way how assembly and C based MIOS applications are built under different operating systems (Windows, Linux, MacOS) for different PIC processors (PIC18F452/PIC18F4620/PIC18F4685), and it allows to share code modules between different projects without copying source files to improve the collaboration of people who are interested to contribute.
The file structures and build procedures have been defined for the special needs of this community. Most important intention was to ensure, that end-users without programming skills are still able to customize and recompile an application safely without running into issues like file inconsistencies, missing packages or wrong tool configuration.
In order to achieve this, the file structure exists in different āviewsā for users and programmers (more about this topic below).
Application Release Packages
All applications have been re-released and they are now available in the MIOS download section.
They contain the prebuilt .hex file + source code as before, but the file structure inside the package has been changed. There are subdirectories for include files (include/), low-level drivers (modules/), libraries (lib/), scripts (bin/), documentation (doc/), and mostly also a separate source directory for the main program (src/).
Each package contains a README.txt file, where an introduction and sometimes also links to websites with more informations can be found.
A āMakefileā and āMakefile.origā is part of the package as well. āMakefile.origā contains the original instructions to build the application, and the āMakefileā includes this file after setting MIOS_PATH and MIOS_BIN_PATH to the local release directory. This approach ensures, that users will always re-compile an application with the same resources used (and tested) by the programmer during a release.
To rebuild an application different open source tools are required.
Details are eplained in the Wiki (installation docs mainly written by StrydOne and Audiocommander - thank you!)
http://www.midibox.org/dokuwiki/application_development
Windows users: see especially this page
http://www.midibox.org/dokuwiki/windows_toolchain_quickstart
After installation of the toolchain, all you need to do for recompiling an application is to
- open a command shell
- change to the release directory ācd <dir>ā
- type āmakeā
Itās identical for all operating systems.
MIOS Base Package
Those who donāt intend to program applications can stop reading here!
While application releases only contain the used files/directories (a small part) of the programming platform, the base package contains all available include files, libraries, modules which were available at a given released date. It also includes programming examples and templates in the apps/ directory.
In order to create a new application, just copy a template into a new directory and start with programming (e.g., try the MIOS C programming examples).
To build a .hex file, the MIOS_PATH and MIOS_BIN_PATH environment variables have to point to the base package directory (MIOS_BIN_PATH points to the bin directory inside the base package). These variables can be set in the command shell; Linux/MacOS users can insert them into a ~/.bash_login (or similar) file, Windows users can add them to the system properties (one of those well hidden GUIs) so that the variables are already set correctly when a new command shell is opened.
Example for DOS:
set MIOS_PATH=C:\mios_base
set MIOS_BIN_PATH=C:\mios_base\bin
Example for Linux/MacOS:
export MIOS_PATH=~/mios_base
export MIOS_BIN_PATH=~/mios_base/bin
To share an application with other users, copy it into a new directory, type āmake distā and follow the instructions.
And/or bring it into the repository! (see below)
MIOS Repository
Alternatively to using the MIOS base package, itās also possible to download the current sources of MIOS base + all applications from the midibox server via SVN.
This method could also be interesting for users who want to try out new features of applications, before they have been released.
Once the complete repository is on your harddisk, you are able to keep it up-to-date by using the SVN sync mechanism (āsvn updateā) - monthly/weekly/daily/hourly/whenever you want. Only the differences will be downloaded.
The SVN URL (for read access only) is: svn://svnmios.midibox.org/mios
Linux/MacOS user: āsvnā is (mostly) already installed on your computer. Just type āsvn co svn://svnmios.midibox.org/miosā
Windows users: see http://www.midibox.org/dokuwiki/windows_toolchain_svn
There is also a SVN web frontend installed which allows you to follow the progress without installing SVN:
Write access to MIOS Repository
Every programmer who want to contribute is invited to get write access to the repository. Just contact me!
With SVN write access, you are able to:
- publish new code modules (low-level drivers) and applications for other programmers
- collaborate with other programmers on a single application (subversion supports file merging)
- provide bugfixes for existing code (after agreement with the original programmers/copyright holder(s) of course)
- fix typos and provide translations for ucapps.de (ucapps.de is part of the repository as well)
- provide circuit diagrams under schematics/ (e.g. in xcircuit format)
Have fun! ![]()
