MIOS C Wrapper Beta
The most recent version of the C wrapper is now available for a public beta test: http://www.ucapps.de/tmp/mios_c_wrapper_beta1.zip
This package also contains a binary of the release candidate for MIOS V1.8, which is required to get the wrapper properly working (there is only a small change: FSR0L and FSR0H will be saved on interrupts)
More informations about the C interface can be found here:
http://www.ucapps.de/mios_c.html
Note that the current sdcc has a bug which doesn’t produce proper assembly code for the PIC18F. Please use following sdcc snapshot  instead:
http://www.midibox.org/sdcc_tmp/sdcc-snapshot-i586-mingw32msvc-20040716.zip
Thanks Thorsten!
Everything works great with the old SDCC release.   :slight_smile:
-Graham
Good news!
SDCC has reached a good stability again, so that that the use of the “latest and greatest” build (>20050123) is highly recommented.
Because of some conceptional changes in the compiler a new wrapper is required:
http://www.ucapps.de/tmp/mios_c_wrapper_beta2.zip
You can migrate your existing C code by copying all files from the skeleton directory (and subdirectories) except for main.c into your project directoy.
The only change in main.c:
  void ENC_NotifyChange(unsigned char encoder, unsigned char incrementer)
has been changed to:
  void ENC_NotifyChange(unsigned char encoder, char incrementer)
Snapshot from 20050123 is no longer aviable from SDCC homepage, anyone have it zip’ed ?
Or Is it ok to use a newer snapshot or should i exepct some buggs ? Well, I’ll try anyway…
best
/Wise
Hi Wise,
in the meantime it should be ok to use the “latest and greatest” version
Once I’ve finished the documentation of MIDIbox FM, I will continue with the C stuff. I’m planning a C testsuite (some kind of reliability test) which ensures that the most important C constructs are working, and that all MIOS functions can be accessed
hi
have just build my first midibox and MBHP_BURNER_V1
have trouble to use midi-ox but have managed to use mios studio upload version 1.7 of mios
but i want to program in c and i can only finde a syx file of mios v 1,8 rc1
can you post or send me an hex file of mios 1.8 so i can program in c
and another question  is it okey to use sdcc version 2.5.0
Thanks
Martin
Hi Martin,
yes, SDCC 2.5.0 is ok
I’m just working with the C wrapper and found a major problem in conjunction with MPLAB (first time I’m writing a more complex application with it)
The details can be found here: http://sourceforge.net/tracker/index.php?func=detail&aid=1203088&group_id=599&atid=100599
However, in the meantime I’m using gpasm which is also available for Win32 - it works perfectly.
I will write down the details once the C based MIDIbox MM application is finished and once I’m sure that there is no other issue
.hex file: you will get it via email
The low/high byte order has been changed (again) in SDCC 2.5.0, this means that all MIOS functions which are using 16bit words (like some AIN and BANKSTICK/FLASH/EEPROM functions) don’t work anymore.
However, I will release a new wrapper soon
