MIOS_AIN_Pin8bitGet
do not exist :wink:
Well, i’m very interested in this function, but as i have allready wrote, i not a asm person.
I’ve located the MIOS_AIN_Pin7bitGet function in src/mios_ain.inc
;;  FUNCTION: MIOS_AIN_Pin7bitGet
;;  C_DECLARATION: unsigned char MIOS_AIN_Pin7bitGet(unsigned char pin)
;;  DESCRIPTION: returns 7-bit value of AIN input ....
MIOS_AIN_Pin7bitGet
	andlw	0x3f
	lfsr	FSR1, MIOS_AIN_RESULT_L_00
	addwf	FSR1L, F
	movff	INDF1, MIOS_PARAMETER1
	bsf	FSR1L, 6
	movff	INDF1, MIOS_PARAMETER2
	;; note: a multiplication would work faster, but would overwrite PRODL/PRODH
	rrf	MIOS_PARAMETER2, F
	rrf	MIOS_PARAMETER1, F
	rrf	MIOS_PARAMETER1, W
	andlw	0x7f
	movwf	MIOS_PARAMETER1
	return
But i’m dont know how to understand it  :-\
Can a clever person tell me what to change ? (i suppose it must be pretty simple)
Thanks !!!
Just remove the two first (!) rrf’s + the “andlw 0x7f”
Wow, so fast ! Thanks :slight_smile:
So, is it a good idea to add it into mios_ain.inc or should i use the function as ‘standalone’
If i want to add it to MIOS, what changes should i do to the mios_vectors.inc ???
Thanks
Never add such custom functions into MIOS, it makes your application incompatible.
Just write the function into a seperate .c or .asm or .inc file, this can be distributed very easily.
On the other hand: in my own applications, I don’t call functions for such special conversions at all. I mostly do the conversion directly, which is faster.
In C you only need to write “value >> 2” to get the same effect, so why creating a function?
P.S.: see map.h of the “analog_toolbox” application
I did not think about it ! ( i’m still new to “>>” :wink: )
i did not think about the compatibily too, but hey, you are definitely right !
I guess it’s a newbe behavior : no to see the obvious.
Thanks a lot !!!
