mios 1.8 with bootloader 1.2
hi,i ve got a issue for a loading:
  • a special set up ,for midibox 64 (using the serge editor)
my primary bootloader is 1.2 ,and after several tries,impossible to load the mios 1.8(mios 1.9g works fine).;
Question: if is it possible to load the mios 1.8 with 1.2 bootloader?how can i do that(loading mios 1.8) .thanks for your answers
No, this isn’t possible since v1.2 bootloader overlaps the mios v1.8 address range - but why do you need MIOS V1.8?
Hi TK it’s for the mpg 80(roland mks)MB 64, i am building with Rasmus..the setup.hex(value min ,max is ready :attachement file) but it seems the serge editor doesn’t works with mios 1.9 to load it(this setup)in my bankstick After loading,it’s written “dump invalid”
how can i do? thanks for the answer.
[MKS80_OK.zip](< base_url >/applications/core/interface/file/attachment.php?id=6674)
This issue isn’t related to MIOS, but to your MIDI interface under Windows.
Solution: use MIDI-Ox to upload the .syx file
First enter following setup into the configuration window of the SysEx tool:
Thereafter load the file into the command window of the SysEx tool:
And send it to your MIDIbox:
Sidenote: if this still doesn’t help, you have to generate a .syx file in a newer format which is supported by MIDIbox 64 V2
I created this format since so many people were not able to upload large SysEx dumps with their MIDI interface.
Details are described here:
http://www.ucapps.de/howto_tools_mbsyx.html
Meanwhile, mk_syx is part of the midibox64 package, so it’s already on your harddisk (-> midibox64_v2_4c/tool/mk_syx directory)
i will try this tomorrow ,thanks for your great help…regards
Hi all,the dump works fine with midiox 7.0 and my sound card (rme fireface 800)i will try it with the pots soon.best regards
