midiphy SEQ v4+
Hello!  Been watching this and the original thread for a couple months - Very excited for this even though I’ve started a to gather PCBs and a front panel for a Wilba style build.
For those that don’t want customization (which I gather is part of the concept of v4+ ?), a Single kit order option along with a Single Mouser BOM (or for Europe equivalent) would be amazing.  I think this possibility was mentioned earlier but WOW that would make things so much more accessible for purchasing.
But slow methodical planning of each area is also fun, in a different way :slight_smile:
Incredibly excited for this. Got a fair amount of the components together so eager for the boards etc!
Looks amazing!
Really interested in this v4+ how difficult would the build be? I have very basic soldering experience
Was just saying to Hawkeye that I might do an SMT soldering tutorial using hot air and solder paste if you guys think it would be useful. That might make it more accessible for people as I don’t even trust myself with the drag method using an iron!
Hot air stations can be bought for pretty cheap these days (about 30 euro) and it certainly takes less skill imo. It was actually recommended to me by Sauraen for the MIDIbox Quad Genesis and I quite like it.
I can’t wait to build this guys, the MB-6582 set a benchmark for eye candy for a MIDIbox project, the eye candy and feel of the SEQ V4+ has set a new benchmark imo.
We’re still finalising the pricing. There are more PCBs involved than for a Wilba version, but also less shipping cost (and less hassle).
I have a solder paste gun but I’ve never used it. But alternative build methods are appreciated! I try not to drag/wick as you can damage the solder mask and cause unintentional shorts. I find hot air is really useful if you’ve made a total balls-up though!
As long as your iron is decent (small tip and temp. control) it’s all about heating the SMT pad and wetting the joint properly while not applying too much solder nor overheating the chip. To do this, I hold the iron at a low angle (closer to the PCB) and just go half a chip row at a time.
We will also make a “practice board” available that has examples of 1206/SOT-23/SOIC. Actually it is a MIDI thru splitter with DIN/3.5mm sockets, so if you do a good job you get a nice utility :).
Could you post the dimensions of the unit? It looks like it might stand a bit taller than the Wilba Seq in the Heidenreich case, and in my setup (read: table with rack on top), there’s not much spare room above it. When not doing music, I like to slide it underneath the rack. Thanks a lot!
Of course:
44.5cm width (+ side screwheads, 1 or 2 millimeters on each side)
14 cm depth (front to midi ports)
8 cm height (standing on the table, incl. rubber feet) without the encoder knobs.
With encoder knobs, i’d say currently 9.5cm height, it should go down to 9.3cm - read below.
In conclusion: the case is really compact (for its contents!), we had to do some optimizations to have the waveshare MCU board fit in there, especially we need low-profile female headers on the wCore PCB. But these are available and unproblematic, now all works out. Do you have the Heidenreich case measurements for comparison? I’d be interested!
Regarding the encoder knobs: we will probably suggest to Adrian to counter-sink them “into the frontpanel”, i.e. have bigger cutouts, like another famous sequencer out there :).
This has to do with them not scratching the frontpanel when pushing them down, and optimizing height for another few millimeters.
Have a great weekend, y’all!
Many greets, Peter
4 hours ago, Hawkeye said:
Of course:
Many greets, Peter
Hey Peter,
I measured 43,8cm x 15,7cm x 8,8cm (WxDxH) on mine, including the rubber feet. Encoder knobs top and the (rounded) edge at the back are just about the same height.
You are actually using very tall encoder knobs on the pics. The tapered, low profile ones on the other famous sequentixcer do handle very well i gotta add!
Thanks for info and have a nice weekend, too! BTW, do you not drink beer? Otherwise you should add a “buy Hawkeye a beer” signature, too. I’ll also buy you an Apfelschorle if need be.
Best way to buy Hawkeye a beer is to visit him in Munich! *2 beers maximum applies* :wink:
Guys, I was wondering if all the feature requests TK has implemented in the firmware have been documented anywhere besides on the thread?
I haven’t read through the MIDIbox manual on ucapps and the wiki extensively to make sure.
It would be awesome to have an up to date manual for the SEQ V4(+). Since I’ve a lot of free time I could probably help out with that aspect.
I will gladly help out on that, too!
I saw pictures of Midibox meet-ups back in the PIC-days - are there anymore of those happening? If so, I would be delighted to join.
I’d rather not “countersink” them - I always feel better without dust getting inside the enclosure.
If you mean counterbore(chambering) not sure he will be able to do it because of the panel thickness.
About the other famous sequencer like, I don’t know how it’s made but I’ve got a MPC X and there’s a plastic panel under the front panel
You will get the same problem with the switches, isn’t it? Then…
With a bigger cut-out, the problem is that only one knob diameter will fit inside, so no customisation :wink:
I think about this (thin encoder) diameter is 14.2mm, https://store.djtechtools.com/products/chroma-caps-knobs-and-faders
Have a good afternoon!
Bruno
Yes, and that’s already bad enough, so why open it up for even more dust to enter?
About the dust… I’ve got beautiful dust cover for my 909 and 727 which come from stardust in Portugal, made in Portugal they are able to fab various shape.
https://www.stardustcovers.com/store
We can maybe deal something with them and put it in the shop :wink:
Nice idea!
Above :wink:
1 minute ago, latigid on said:
Nice idea!
You maybe busy, you want me to try, take the first contact?
There’s a lot of new models I just order 2 more: Syncussion and SH-9 :slight_smile:
Nice offer, I would say that I’m interested in the covers to block all of these evil holes, but certainly we wouldn’t be purchasing anything for a long time. If they can give an idea on pricing please let me know!
Done! I return to you and Peter once I’ve got an answer :wink:
It’s only now I realised it has 4 midi ins and 8 midi outs after Hawkeye pointed it out to me!
I think originally Andy in the other thread you were going for 2 midi ins and 6 midi outs?
Just wanted to thank you for giving us the extra ports.
Now I can easily hook up 2 keyboards a drum pad and the LoopA V2 to the input ports when it’s done. :slight_smile:
