cimo
September 12, 2007, 4:53pm
1
hi
i am going to put a midiman 2X2 in my next box, but i don t have one here right now.I need to know the way it looks like inside and in particular the measurements when it is out of its enclosure.Has anybody one of those? can you take a pic at its guts and take a few pictures?
thanks
simone
kris
September 12, 2007, 9:20pm
2
shure i can do that ive just got to charge the battery on my camera
regards kris
kris
September 12, 2007, 10:49pm
3
here you go hope these help although im having problems getting a good close shot
the measurements are 86mm by 63mm
cimo
September 13, 2007, 7:31am
4
hi kris
you re my daily hero
please confirm this: the maximum height of the electronics is actually the height of the midi sockets plus the PCB thickness,right?
Also: when they say that it can also work as a stand alone MIDI hub, does it need to be powered with the USB anyway ?
Simone
opkod
September 13, 2007, 7:40am
5
it is powered via usb for using it with a computer and in stand alone with a thru mode switch that route the inA to outA and inB to outB without any power supply.
kris
September 13, 2007, 8:21am
6
hello cimo
your right the maxium height is midi sockets plus pcb
im not shure about the stand alone midi hub and powering i just power it from usb
regards kris
opkod
September 13, 2007, 8:29am
7
of course, it work without usb…
from m-audio:
2-in/2-out MIDI interface
32 discrete MIDI input channels; 32 discrete MIDI output channels
bus-powered—requires no external power supply
compact and lightweight for mobile or desktop use
standalone mode allows basic throughput even when computer is off
cimo
September 13, 2007, 3:53pm
8
hi
O and K thanks for the infos !!!
Simone
